[ZOO-Discuss] Problem with XML execute request
Luca Delucchi lucadeluge at gmail.com
Wed May 4 05:35:17 PDT 2011
2011/5/4 Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> I use wps-grass-bridge and grass gis 7 as backend. The grass process
> runs perfectly but the zoo kernel crashes while trying to deliver the
> result.
> I have the same problem....
> I didn't notice any issue using your XML request, using the following setup
>    * zoo-kernel trunk rev 206
>    * wps-grass-bridge trunk rev 61
>    * grass trunk rev 45242
I update to this versions but...
> You can use the content of this file from the command line:
> http://zoo-project.org/zcfgs-grass/request_grass_sample.txt
with this request I have again the same problem
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
  <ows:Exception exceptionCode="InternalError">
    <ows:ExceptionText>ZOO Kernel failed to process your request
receiving signal 11 = SIGSEGV</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
> So this should not come from ZOO-Kernel, wps-grass-bridge or
> grass. Maybe, there
> is some more info in the setup (zcfg files [1] used or
> GlobalGrassSettings.py - GGS [2]) ?
> I think that we should take a look at the generated zcfg files. Please, can
> you give me
> access to your v_voronoi.zcfg file ?
http://www.lucadelu.org/out/v_voronoi.zcfg
http://www.lucadelu.org/out/GlobalGrassSettings.py
> Hope to hear from you, thanks for your help.
> Best,
> Gérald Fenoy
thanks and regard
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
