[ZOO-Discuss] Java based Service: <ows:ExceptionText>can't find class ZooWrapper.class</ows:ExceptionText>
Matthias Lendholt
matthias.lendholt at gfz-potsdam.de
Thu May 5 06:52:07 PDT 2011
Dear all,
I tried to setup a very simple Java Process and followed the demo in the
wiki.
ZooWrapper.class is stored in the cgi-bin directory and TestJava.zcfg is
pointing to it.
*ls*
/usr/lib/cgi-bin$ ls
HelloPy.zcfg mapserv test_service.py ZooWrapper.class
main.cfg TestJava.zcfg zoo_loader.cgi
*zcfg*
[Test]
Title = Display a string
Abstract = Display a string which contains an hello message
processVersion = 1
storeSupported = true
statusSupported = true
serviceProvider = ZooWrapper.class
serviceType = Java
<MetaData>
title = Demo
</MetaData>
<DataInputs>
[S]
Title = the string
Abstract = The string to add to the hellow one.
minOccurs = 1
maxOccurs = 1
<LiteralData>
DataType = string
<Default>
</Default>
</LiteralData>
</DataInputs>
<DataOutputs>
[Result]
Title = The hello string
Abstract = The Hello message string.
<LiteralOutput>
DataType = string
<Default>
</Default>
</LiteralOutput>
</DataOutputs>
*ServerRequest*
http://192.168.56.101/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Version=1.0.0&Identifier=TestJava&DataInputs=S=TesT
*ServerResponse*
<?xml version="1.0" encoding="utf-8"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
<ows:Exception exceptionCode="NoApplicableCode">
</ows:Exception>
</ows:ExceptionReport>
Content-Type: text/xml; charset=utf-8
Status: 200 OK
Are there any other Java specific settings? Must a classpath env be set?
For testing ZooWrapper is in the default package. However, is it
possible to store Java classes in jar files under package structure? I
couldn't find any specific documentation for Java-based processes.
Many thanks in advance,
Matthias
More information about the Zoo-discuss
