[ZOO-Discuss] Using zoo project to process a raster file
Thomas Tilak
thomas.tilak at gmail.com
Tue May 24 14:54:30 PDT 2011
Hello,
I am trying to use zoo project framework to process a raster file (actually,
for now just to extract a ROI).
I have performed zoo project workshop and I have studied the Boundary C
function hoping to use it to write my extract function.
I have a problem with the inputs. I am using th console version with the
following commands:
./zoo_loader.cgi
"request=Execute&service=WPS&version=1.0.0&Identifier=Boundary&DataInputs=InputPolygon=Reference at xlink
:href=http%3A%2F%2Fwww.zoo-project.org
%3A8082%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.28&RawDataOutput=Result at mimeType
=application/json"
./zoo_loader.cgi
:href=%2Fhome%2Fuser%2Ftest_gml.gml&RawDataOutput=Result at mimeType
=application/json"
The first command works perfectly but in the second one, it crashes and
gives the message: "ZOO Kernel failed to process your request receiving
signal 11 = SIGSEGV"
I have attached the gml file used to my message.
I would like to know how exactly should be the inputs set to fit zoo project
expectations. Do you have an example of service working with raster file?
Thank you.
Thomas.
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110525/51b01ff5/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110525/51b01ff5/attachment.obj>
More information about the Zoo-discuss
