[Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
Fenoy Gerald gerald.fenoy at geolabs.fr
Tue Dec 3 02:17:23 PST 2013
Christian,
please may I ask you to try with the new file again ?
I’ve added the ResponseForm that I removed by mistake, it should cause troubles. You can even try to remove the default input mimeType to go back to text/xml as default and application/json as supported one. Indeed, I made a mistake earlier when I said in my email that you got both ResponseDocument and RawDataOutput. It was ResponseForm not ResponseDocument so no need to remove it.
I hope this solve your issue this time.
Hope to hear back from you,
Best regards,
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131203/00293300/attachment.html>
Gérald Fenoy
Le 2 déc. 2013 à 19:33, Christian Rüh <christian.rueh at uni-rostock.de> a écrit :
> Hi Gerald,
> thanks for your answer :-)
> But, nope, the response still has all the WPS stuff around the GeoJSON, i.e. nothing has changed. I really hope that that's the problem and I'm not wrong with that. But if it is I just don't know a way to remove the "padding" and just use the GeoJSON String...
> Cheers and thanks again,
> Christian
> Am 02.12.2013 19:14, schrieb Fenoy Gerald:
>> Christian,
>> maybe try with this new zoo-ogr2.html file, I removed the space prior to each lines from 108 to 125 where it creates the XML request. It may help with old versions.
>> Hope this helps,
>> Best regards,
>> Gérald Fenoy
>> Le 2 déc. 2013 à 18:26, Christian Rüh
>>  a écrit :
>>> Hi Gerald,
>>> wow, clever solution for that, thanks so much :-)
>>> The remaining issue seems to be the "padding" (the whole WPS request stuff in XML). The POST response should be just the GeoJSON part but isn't.
>>> Cheers and thanks,
>>> Christian
>>> Am 02.12.2013 17:23, schrieb Fenoy Gerald:
>>>> Christian,
>>>> even if it should work using the parameters I sent (at least with newer ZOO-Kernel version), I guess there is still something wrong in the ZOO-Kernel you are using. But there is probably some way to solve, I guess you may first try to define the application/json mimeType as the default one in the Union.zcfg file for the output Result.
>>>> Hope to hear back from you and this sole your issue,
>>>> Best regards
>>>> Gérald Fenoy
>>>> Le 2 déc. 2013 à 17:00, Christian Rüh
>>>>  a écrit :
>>>>> Hi Gerald,
>>>>> thank you very much :-)
>>>>> Unfortunately that does not change anything and the result is still the same. RawDataOutput and the mimeType seem to not to play any role at all when it comes to the response. It remains in GML format. I'm pretty lost now and don't know what else could be wrong...
>>>>> Cheers and thanks,
>>>>> Christian
>>>>> ________________________________________
>>>>> Von: Fenoy Gerald [
>>>>> Gesendet: Montag, 2. Dezember 2013 16:39
>>>>> An: Christian Rüh
>>>>> Cc: ZOO-discuss
>>>>> Betreff: Re: [Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
>>>>> Hi Christian,
>>>>> I think that the new file attached to this email should fix the issue by adding a mimeType attribute to a new Output node added to the request sent by your zoo-ogr2.html file.
>>>>> I noticed that you got both ResponseDocument and RawDataOutput nodes in your POST request which sounds odd to me.
>>>>> I hope to hear back from you and the file solve your issue.
>>>>> Best regards,
>>>>> Gérald Fenoy
>>>>> _______________________________________________
>>>>> Zoo-discuss mailing list
>>>>> Zoo-discuss at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131203/00293300/attachment.pgp>
More information about the Zoo-discuss mailing list
