[Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
Christian Rüh
christian.rueh at uni-rostock.de
Mon Dec 9 02:06:25 PST 2013
Hi Gerald,
thanks for the file :-)
However, it still does not work :-(
But I'll leave it alone at this point and will have a look at it again some time next year when I need it again for my students. If I still have questions then I'll contact you/the mailing list.
Thanks for all the time and effort you put into this :-)
Cheers and thanks again,
Christian
________________________________________
Von: Fenoy Gerald [gerald.fenoy at geolabs.fr]
Gesendet: Dienstag, 3. Dezember 2013 11:17
An: Christian Rüh
Cc: ZOO-discuss
Betreff: Re: [Zoo-discuss] [ZOO-Discuss] FOSS4G 2010 ZOO Workshop Problem
Christian,
please may I ask you to try with the new file again ?
I’ve added the ResponseForm that I removed by mistake, it should cause troubles. You can even try to remove the default input mimeType to go back to text/xml as default and application/json as supported one. Indeed, I made a mistake earlier when I said in my email that you got both ResponseDocument and RawDataOutput. It was ResponseForm not ResponseDocument so no need to remove it.
I hope this solve your issue this time.
Hope to hear back from you,
Best regards,
More information about the Zoo-discuss
