[Zoo-discuss] Problems on Mac OS X
Thomas Tilak
thomas.tilak at gmail.com
Mon Jul 1 02:13:30 PDT 2013
Hi everybody,
I got trouble using zoo_project on Mac OS X. I used the installer and the
getCapabilities is working very well.
I compiled the gdal translate service and tried to use with the following
parameters :
http://localhost:8888/cgi-bin/zoo_loader.cgi?service=wps&version=1.0.0&request=execute&identifier=gdal_translate&dataInputs=Format=tiff;InputDSN=/********.TIF;OutputDataSourceName=/Users/***/Desktop/test.tif
The error is
<?xml version="1.0" encoding="utf-8"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="
http://www.w3.org/1999/xlink" xsi:schemaLocation="
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang=
"en-US" version="1.1.0">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>C Library can't be loaded
</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
So I tried to recompile the zoo_loader.cgi and doing so, I got the
following for the configure command :
./configure --with-python
--with-gdal-config=/Library/Frameworks/GDAL.framework/Versions/Current/Programs/gdal-config
checking for bison... bison -y
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -ll
checking whether yytext is a pointer... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for a sed that does not truncate output... /usr/bin/sed
checking for cgiMain in -lcgic... no
checking for curl_easy_init curl_easy_setopt curl_easy_cleanup
curl_easy_perform in -lcurl... no
checking for dlopen dlsym dlerror dlclose in -ldl... no
checking for main in -lfl... no
checking for main in -lpthread... yes
checking for main in -lfcgi... yes
checking for main in -lssl... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for size_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for inttypes.h... (cached) yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking malloc.h usability... no
checking malloc.h presence... no
checking for malloc.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int8_t... yes
checking for pid_t... yes
checking for size_t... (cached) yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint8_t... yes
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking for GNU libc compatible malloc... yes
checking for GNU libc compatible realloc... yes
checking for dup2... yes
checking for getcwd... yes
checking for memset... yes
checking for setenv... yes
checking for strdup... yes
checking for strstr... yes
checking for gdal-config... /usr/local/bin/gdal-config
checking for xml2-config... /usr/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating ZOOMakefile.opts
By the way, using the with-java=macos, I got "configure: error: could not
find headers include related to libjava" so I removed the parameter for I
do not intend to use java.
Anyway, I am worried about the "checking for cgiMain in -lcgic... no
checking for dlopen dlsym dlerror dlclose in -ldl... no". Is that normal,
could it be the cause of my problem? How could I fix it? I checked for
libcurl and dl files and I found them.
Hope you could help me.
Regards.
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20130701/e2d6fdc9/attachment.html>
More information about the Zoo-discuss
