[Zoo-discuss] RE Default Processes of ZooProject
Fenoy Gerald
gerald.fenoy at geolabs.fr
Fri Jul 25 01:54:13 PDT 2014
if it is doable through Grass it means also that this should be doable through ZOO-Services using the WPS-GRASS-Bridge or Python API.
It would be much appreciated if Quang can give details about his usage of GRASS through Python API to create new ZOO-Services. One example of service should be enough I think to make everybody able to use the GRASS Python API in an easy way.
Anyway, in the upcoming weeks I will work on new services, so ideas are welcome, so lamiaa if you can give more details about your expectations I can implement the service you require shortly.
I hope to hear back from you,
Best regards,
ps: if you simply need to create contour lines from a dtm file then you can simply use gdal_contour, I know this is a trivial service but it works like a charm.
Le 24 juil. 2014 à 18:51, Markus Neteler <neteler at osgeo.org> a écrit :
> Hi,
> another option might be to write 4 lines using GRASS GIS:
> - v.in.ogr vectormap out=map
> - g.region vect=map res=targetresolution
> - r.external.out geotiff ...
> - r.to.vect ...
> Done.
> This requires GRASS 7.
> Cheers
> Markus
> On Jul 24, 2014 6:38 PM, <Steve.Toutant at inspq.qc.ca> wrote:
> Have a look at the gdal service in trunk
> http://zoo-project.org/trac/browser/trunk/zoo-project/zoo-services?order=name#gdal
> Rasterize is not there but you could start from an existing example.
> Perhaps there are more process somewhere...
> steve
> lamiaa khazaz <lamiaa.perso at gmail.com>@lists.osgeo.org
> Envoyé par : zoo-discuss-bounces at lists.osgeo.org
> 2014-07-24 11:03
> A
> ZOO-discuss <zoo-discuss at lists.osgeo.org>
> cc
> Objet
> [Zoo-discuss] Default Processes of ZooProject
> Hello,
> i'm looking for the default functions and processes in Zoo Project, is there any help page where i can find them ?
> For exemple i would like to rasterize a vector layer, so wich process should i call via Zoo.process.
> Thank you
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140725/3258ef4e/attachment.pgp>
More information about the Zoo-discuss
