[Zoo-discuss] RE Default Processes of ZooProject
Venkatesh Raghavan venka.osgeo at gmail.com
Fri Jul 25 02:09:43 PDT 2014
Gerald and all,
On 2014/07/25 17:54, Fenoy Gerald wrote:
> Hi, if it is doable through Grass it means also that this should be
> doable through ZOO-Services using the WPS-GRASS-Bridge or Python
> API.
That is easily dooable. I think Bomp has also implemented this using
GRASS-6.4 and 7 too.
Bomp, Quang send us a couple of examples of GRASS WPS implemented using
ZOO.
Best
Venka
> It would be much appreciated if Quang can give details about his
> usage of GRASS through Python API to create new ZOO-Services. One
> example of service should be enough I think to make everybody able to
> use the GRASS Python API in an easy way.
> Anyway, in the upcoming weeks I will work on new services, so ideas
> are welcome, so lamiaa if you can give more details about your
> expectations I can implement the service you require shortly.
> I hope to hear back from you, Best regards,
> ps: if you simply need to create contour lines from a dtm file then
> you can simply use gdal_contour, I know this is a trivial service but
> it works like a charm.
More information about the Zoo-discuss mailing list
