[Zoo-discuss] POST not implemented
Steve.Toutant at inspq.qc.ca
Mon Jul 28 08:41:22 PDT 2014
I cannot tell if zoo is correct or not. But having a CDATA in an XML
document is a common thing.
http://www.w3schools.com/xml/xml_cdata.asp
In my case, I'm (trying) using openlayers wps client to generate de XML to
send to the wps server. Ol put CDATA in the XML.
Steve
Fenoy Gerald <gerald.fenoy at geolabs.fr>@lists.osgeo.org
Envoyé par : zoo-discuss-bounces at lists.osgeo.org
2014-07-28 11:17
A
pablo zader <pzader at gmail.com>
cc
ZOO-discuss <zoo-discuss at lists.osgeo.org>
Objet
Re: [Zoo-discuss] POST not implemented
Dear Pablo,
thanks for providing your XML request.
>From my point of view, there is an issue in the request you provided, you
defined the mimeType attribute of your ComplexeData node to « text/xml »
which is valid, but then, rather than providing a XML node in the request,
you provided a CDATA node which should be used for ComplexData with the
mimeType defined to application/json for instance.
In the case of mimeType defined to text/xml, the ZOO-Kernel is searching
for a XML node which will be used as a root of a new document which will
then be used to POST the request to the targeted server.
So your request should work by removing both: « <![CDATA[ » and « ]]> »
from its content.
If anybody think that it is wrong to handle the text/xml content the way
ZOO-Project is doing, then please speak up and let me know.
I wonder, cause it is not the first time that somebody send such kind of
requests. The issue Steve faced with his request was really similar to
this one.
We may fix the issue directly in the Client code maybe ?
Waiting for your answer,
Best regards,
Le 28 juil. 2014 à 16:27, pablo zader <pzader at gmail.com> a écrit :
> Hi list,
> I'm developing a client wps modifying the example WPSDemo.js from
> http://suite.opengeo.org/4.1/processing/wpsclient/index.html .
> I'm using zoo-proyect as wps server.
> I'm trying to invoke the buffer process implemented in GRASS GIS gives
me the following error:
> POST
http://localhost:9080/proxy/?url=http%3A%2F%2Flocalhost%2Fcgi-bin%2Fzoo_loader.cgi%3F
501 (Not Implemented)
> The query POST is:
> <wps:Execute xmlns:wps="http://www.opengis.net/wps/1.0.0"
version="1.0.0" service="WPS" xsi:schemaLocation="
http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"><ows:Identifier xmlns:ows="
http://www.opengis.net/ows/1.1
">v_buffer</ows:Identifier><wps:DataInputs><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1
">input</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Or data source for direct OGR
access</ows:Title><wps:Data><wps:ComplexData
mimeType="text/xml"><![CDATA[<wfs:FeatureCollection xmlns:wfs="
http://www.opengis.net/wfs"><gml:featureMember xmlns:gml="
http://www.opengis.net/gml"><feature:features xmlns:feature="
http://mapserver.gis.umn.edu/mapserver"
fid="OpenLayers_Feature_Vector_248"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates
decimal="." cs="," ts=" ">-6383273.5489707,1396657.4552779
-4230806.8327598,26905.908598173 -6246298.3943028,-442723.19312058
-6383273.5489707,1396657.4552779</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:features></gml:featureMember></wfs:FeatureCollection>]]></wps:ComplexData></wps:Data></wps:Input><wps:Input><ows:Identifier
">layer</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">A single vector map can be connected to
multiple database tables. This number determines which table to use. When
used with direct OGR access this is the layer
name.</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">cats</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Example:
1,3,7-9,13</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">where</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Example: income 1000 and inhab ::
10000</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">type</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Feature
type</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">distance</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Buffer distance along major axis in map
units</ows:Title><wps:Data><wps:LiteralData>195678.7923828125</wps:LiteralData></wps:Data></wps:Input><wps:Input><ows:Identifier
">minordistance</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Buffer distance along minor axis in map
units</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">angle</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Angle of major axis in
degrees</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">bufcolumn</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Name of column to use for buffer
distances</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">scale</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Scaling factor for attribute column
values</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
">tolerance</ows:Identifier><ows:Title xmlns:ows="
http://www.opengis.net/ows/1.1">Maximum distance between theoretical arc
and polygon segments as multiple of
buffer</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-s</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Make outside corners
straight</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-c</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Dont make caps at the ends of
polylines</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-t</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Transfer categories and
attributes</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input></wps:DataInputs><wps:ResponseForm><wps:RawDataOutput
mimeType="text/xml"><ows:Identifier xmlns:ows="
">output</ows:Identifier></wps:RawDataOutput></wps:ResponseForm></wps:Execute>
> Thanks in advanced
> P.
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140728/32657dcf/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140728/32657dcf/attachment-0001.obj>
More information about the Zoo-discuss
