[Zoo-discuss] POST not implemented
Fenoy Gerald
gerald.fenoy at geolabs.fr
Mon Jul 28 14:10:40 PDT 2014
HI all,
from revision 496 [1] the ZOO-Kernel handle both cases. As before, when a XML document is embedded in another, which is quite common practice, the ZOO-Kernel parse the XML content using the first ComplexData children node, which is a XML_ELEMENT_NODE, as root for creating a document. In case there is a CDATA element encapsulating the XML content, then the ZOO-Kernel uses the content of the CDATA to define the value of the input rather than trying to parse the XML content.
Hope this helps and you can confirm this solves your issue.
Best regards,
[1] http://zoo-project.org/trac/changeset/496
Le 28 juil. 2014 à 17:41, Steve.Toutant at inspq.qc.ca a écrit :
> I cannot tell if zoo is correct or not. But having a CDATA in an XML document is a common thing.
> http://www.w3schools.com/xml/xml_cdata.asp
> In my case, I'm (trying) using openlayers wps client to generate de XML to send to the wps server. Ol put CDATA in the XML.
> Steve
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140728/5866bd72/attachment.pgp>
More information about the Zoo-discuss
