[Zoo-discuss] Working demo
Fenoy Gerald gerald.fenoy at geolabs.fr
Wed May 7 00:55:18 PDT 2014
Dear Steve,
my answer inline bellow.
Le 6 mai 2014 à 15:12, Steve.Toutant at inspq.qc.ca a écrit :
> Thank you all for your answers.
> I didn't know osgeolive and didn't understand what it was.
> The demo is working on the Web Site thank you. Spatial queries with WFS and WPS is what I need.
> At this page, http://live.osgeo.org/fr/quickstart/zoo-project_quickstart.html
> "You can build your own requests and send them to the ZOO Kernel from the following page:"
> http://localhost/zoo-demo/test_services.html
> What is this demo? Can we specify our own WFS layer as Input?
This demo is simple HTML form which makes you able to send POST requests to the ZOO-Kernel and run your services by writing requests by hand.
Obviously you can use your own WFS layer to request any service, you simply have to pass its value « by reference » (using a xlink:href link in the request) using the GetFature request to your WFS server.
> Also, I ran http://www.zoo-project.org/cgi-bin-new1/zoo_loader.cgi?Request=GetCapabilities&Service=WPS
> Are those processes included in zoo when installing?
No process are included when you install the ZOO-Kernel, you will have to deploy services which are available in the zoo-services directory on the SVN [1]. For not C based services it is an easy step to deploy, it consist simply in copying the zcfg files and its companion Python module in the same directory as the ZOO-Kernel. Note that since some time now, you can also deploy your services in subdirectory, their names will then be slightly modified to be prefixed by the sub-directory name. So for instance if you put the Delaunay and Vornoi service in a cgal subdirectory of your Apache cgi-bin directory you will then have access to the service named cgal.Delaunay or cgal.Vornoi.
> And....Any experience on installing Zoo on CENTOS 6
Nicolas already this question.
> Thanks again
> Steve
> Fenoy Gerald <gerald.fenoy at geolabs.fr>
> 2014-05-06 08:50
> A
> cc
> Angelos Tzotsos <gcpp.kalxas at gmail.com>, ZOO-discuss <zoo-discuss at lists.osgeo.org>
> Objet
> Re: [Zoo-discuss] Working demo
> Dear Steve,
> I agree with you that ZOO-Project web site demo should work.
> I had applied the patch provided by Angelos on the web site so the demo should work now.
> Nevertheless, as Jeff mentioned there was an issue with base layer availability but both the server and services were working (even if it is a really ZOO-Kernel version and also old services).
> About the second link you provided ([1]) I guess you find it in the workshop material ? If yes, then you should understand that the workshop should be run from the OSGeoLiveDVD environment so the links will work there. In case you would appreciate or think it may help in any way to have those demo setup on the web site feel free to ask and we can handle it easily.
> Waiting for your feedbacks,
> Best regards
> [1] http://localhost/zoo-demo/spatialtools.html
> Le 6 mai 2014 à 14:34, Steve.Toutant at inspq.qc.ca a écrit :
> > I think ZOO should have a working demo on their Web site. Like other WPS framework..
> > Steve
> > 2014-05-05 20:09
> > A
> > Steve.Toutant at inspq.qc.ca, zoo-discuss at lists.osgeo.org
> > cc
> > Objet
> > Hi,
> > ZOO has a working demo within OSGeoLive (http://live.osgeo.org/)
> > Best,
> > Angelos
> > On 05/05/2014 11:03 PM, Steve.Toutant at inspq.qc.ca wrote:
> > Hello
> > we are looking for a WPS framework.
> > I found links to demos but none are working
> > http://zoo-project.org/site/ZooWebSite/Demo/SpatialTools
> > http://localhost/zoo-demo/spatialtools.html (links to localhost)
> > Is there a working demo somewhere?
> > thanks
> > Steve
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> > Angelos Tzotsos
> > Remote Sensing Laboratory
> > National Technical University of Athens
> > http://users.ntua.gr/tzotsos
> Gérald Fenoy
> <signature.asc>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140507/2d68a76f/attachment.pgp>
More information about the Zoo-discuss mailing list
