[Zoo-discuss] problem ZOO-proyect WPS and GRASS
pablo zader pzader at gmail.com
Tue May 13 08:35:21 PDT 2014
Hello list
I have a problem trying to run a WPS process through QGIS. (attach print
screen)
TRACE : GDLA error while import. Unable to create input location from input
/tmp/zoo-project/tmpXCXRn6/input_0 GDAL log: Location <workLocation>
created Default driver / database set to: driver: sqlite database:
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db DBMI-SQLite driver error:
Error in sqlite3_prepare(): near "JOIN": syntax error ERROR: Unable to
create table: 'create table input (cat integer, AREA double precision,
PERIMETER double precision, URUGUAY_ integer, X double precision, Y double
precision, NOMBRE varchar ( 7 ), JOIN integer)' TRACE : <class
'gms.ErrorHandler.GMSError'> Unable to run your python process properly.
Please check the following messages : [' File
"/var/www/localhost/cgi-grass/v_buffer.py", line 7, in v_buffer\n
service.fromMaps("v.buffer", inputs, outputs)\n', ' File
"/var/www/localhost/cgi-grass/ZOOGrassModuleStarter.py", line 77, in
fromMaps\n self._importData()\n', ' File
"/var/www/localhost/cgi-grass/gms/GrassModuleStarter.py", line 484, in
_importData\n self._createInputLocation(input)\n', ' File
"/var/www/localhost/cgi-grass/gms/GrassModuleStarter.py", line 603, in
_createInputLocation\n raise GMSError(log)\n']
I'm using the server wps
http://zoo-project.org/cgi-grass/zoo_loader.cgithrough QGIS plugin
WPS-CLIENT 1.0.2 and the geoprocess v_buffer . My data
source is a vector of polygon type taken from my local server.
The same applies to any process you may have.
Thanks
Pablo
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140513/f8b3e6d2/attachment.html>
More information about the Zoo-discuss mailing list
