[Zoo-discuss] during compilation - fatal error: cgic.h: No such file or directory
karsten
karsten at terragis.net
Wed Feb 4 15:07:15 PST 2015
Thanks Gerald et all,
I tried your suggestions below but somehow it just did not work.
Thus I installed from scratch again into a new Ubuntu 14 server, did try to
do the configuration correctly and now at least get to the login page -
hooray !
I tweaked some settings but am stuck once more after I log in to MapMint (
it says login successful - user authenticated !) but then next I get the
page saying
Error!
Requested page could not be loaded
[Errno 2] No such file or directory: '/var/data/public_maps/'
See below http://terra3.terragis.net/ui/Dashboard
Thus I think the configuration is not quite correct yet but at this stage I
am not sure which setting is wrong.
There no error in the Apache log any more , but in the pg log I have this:
2015-02-04 17:47:18 EST ERROR: syntax error at or near "[" at character 201
2015-02-04 17:47:18 EST STATEMENT: SELECT users.*,(select name from
mm.groups where id=id_group) as gname FROM mm.users,mm.user_group,mm.groups
WHERE mm.users.id=id_user AND mm.groups.id=id_group AND adm=1 AND
login='test' AND passwd=[_password_]
Seem that in the statement above the password is not resolved , somehow it
can not be retrieved in the code ...
Below are my 'main' settings from main.cfg
Any thoughts how to fox this ?
Cheers
Karsten
[main]
isTrial=true
encoding=utf-8
mmAddress=/ui
dataPath=/var/data
jsCache=dev
tmpPath=/var/www/tmp
supportedDbs=PostGIS,MySQL,WFS
cacheDir=/var/www/cache
3D=false
rootUrl=/mapmint/public/
publicationUrl=/mapmint/pm/
dblink=/var/data/mm.db
mmPath=/home/src/mapmint/mapmint-ui
#/mapmint/mapmint-ui/
version=1.0.0
Rpy2=true
dbuser=npdb
sessPath=/tmp
applicationAddress=http://localhost/mapmint/mapmint-ui
dbuserName=mm_db
publicationPath=/var/www/mapmint/pm
cssCache=prod
msOgcVersion=1.0.0
serverAddress=http://localhost/cgi-bin/mm/zoo_loader.cgi
lang=en-US,ja-JP
crs=IGNF:LAMB93
cookiePrefix=MMID
templatesAddress=http://127.0.0.1/mapmint/tmpl/
language=en-US
mapserverAddress=http://localhost/cgi-bin/mapserv.cgi
tmpUrl=http://127.0.0.1/mapmint/tmp/
templatesPath=/home/src/mapmint/mapmint-ui/templates
Hi Karsten,
thanks for your feedbacks.
I fixed the typo and order issue you mentioned.
About your specific issue, you should make sure that the apache user, which
should be www-data if you are using Ubuntu, is allowed to access the 3
directories mapmint-services, mapmint-ui and public_map (run chown o+rx on
the directories from root). To test this, you may simply run the following:
cd $SRC/mapmint
sudo -u www-data ls mapmint-services mapmint-ui publica_map
If this works then you should try to see in the apache error log file to see
if more informations are available for understanding what is happening.
I hope this helps you to solve the issue,
Best regards,
More information about the Zoo-discuss
