[Zoo-discuss] during compilation - fatal error: cgic.h: No such file or directory
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri Jan 16 08:38:10 PST 2015
Karsten,
to build the qrencode service, you should run the make command in the following directory:
$SRC/zoo/zoo-project/zoo-services/qrencode/
Then from here, you should find the cgi-env directory with your service to deploy.
Hope this helps,
Best regards,
> Le 16 janv. 2015 à 17:06, karsten <karsten at terragis.net> a écrit :
> Hi Gerald
> That’s that part seems to be working correct now.
> Now I get a installation hiccup with copying a directory - when installing
> the QREncode service
> form  the /qrencode-3.4.1 dir I do
> sudo cp cgi-env/* /usr/lib/cgi-bin/mm/
> Give s me
> cp: cannot stat 'cgi-env/*': No such file or directory
> When I look on the system this dir is not available in there but there are
> multiple such dir in the MapMint dir tree but I am not sure which one needs
> to be copied here ?
> Thanks
> Karsten
> -----Original Message-----
> From: Fenoy Gerald [mailto:gerald.fenoy at geolabs.fr]
> Sent: Friday, January 16, 2015 3:10
> To: karsten at terragis.net
> Cc: ZOO-discuss
> Subject: Re: during compilation - fatal error: cgic.h: No such file or
> directory
> Hi Karsten,
> I made simple modifications to the configure.ac and Makefile.in for each C
> service in such a way that informations about MapServer for instance are
> directly accessed from the ZOOMakefile.opts file located in your ZOO-Kernel
> directory. This way you should not face any issue anymore about wrong
> options when trying to compile the MapMint C Services.
> I hope this will solve your issue,
> Best regards,
>> Le 16 janv. 2015 à 01:22, karsten <karsten at terragis.net> a écrit :
>> Hi Gerald,
>> Yes I am excited to try it.
>> I checked out the updated source code for mm.
>> I retried to compile and again when Building MapMint C Services I get
>> an error after I do
>> cd $SRC/mapmint/mapmint-services
>> for i in *-src ; do
>> echo $i
>> cd $i
>> autoconf
>> ./configure --with-zoo-kernel=$SRC/zoo/zoo-project/zoo-kernel
>> --with-mapserver=$SRC/mapserver-6.2.0
>> make
>> cd ..
>> done
>> I get the following now:
>> g++: error: /home/src/mapserver-6.2.0/libmapserver.a: No such file or
>> directory
>> make: *** [cgi-env/service.zo] Error 1 symbol-tools-src
>> configure: WARNING: unrecognized options: --with-mapserver
>> There is no file libmapserver.a on the system But I have
>> /home/src/mapserver-6.2.0/libmapserver.la
>> /home/src/mapserver-6.2.0/.libs/libmapserver.la
>> /home/src/mapserver-6.2.0/.libs/libmapserver.lai
>> /usr/lib/libmapserver.la
>> How can this be fixed ?
>> Cheers
>> Karsten
>> Sent: Thursday, January 15, 2015 2:22
>> Cc: ZOO-discuss
>> directory
>> Hi Karsten,
>> nice to hear that you try to setup the ZOO-Project and MapMint.
>> I suppose that the issue come from the vector-tools services, so I
>> committed the required modifications on github lately [1].
>> I hope this will solve your issue and you can confirm it was solved.
>> Best regards,
>> [1]
>> https://github.com/mapmint/mapmint/commit/f2a7df571aff1661ced39c5c597a
>> ecdc00
>> 3b62a7
>>> Le 14 janv. 2015 à 23:45, karsten <karsten at terragis.net> a écrit :
>>> Hi All,
>>> I am trying to install zoo (in conjunction with mapmint) on
>>> ubuntu14.04. I
>> get an error during compilation :
>>> I get the error below when trying to compile from the instruction at
>>> https://github.com/mapmint/mapmint/blob/master/INSTALL.md
>>> doing this
>>> for i in *-src ; do
>>> echo $i
>>> cd $i
>>> autoconf
>>> make
>>> cd ..
>>> done
>>> I get this error:
>>> In file included from service.c:48:0:
>>> /home/src/zoo/zoo-project/zoo-kernel/service_internal.h:44:18: fatal
>>> error: cgic.h: No such file or directory  #include "cgic.h"
>>> Note: I can find the file cgic.h in two place on the system
>>> /home/src/zoo/thirds/cgic206/cgic.h
>>> /home/src/zoo_test/thirds/cgic206/cgic.h
>>> Any ideas how to fix this ?
>>> Karsten
>>> Karsten Vennemann
>>> Principal
>>> Terra GIS LTD
>>> 2119 Boyer Ave E
>>> Seattle, WA  98112
>>> USA
>>> www.terragis.net
>>> Phone ++1 206 905 1711
>>> Fax      ++1 925 905 1711
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
Gérald Fenoy
More information about the Zoo-discuss mailing list
