[Zoo-discuss] Issue compiling from source on ubuntu 14.04
Fenoy Gerald
gerald.fenoy at geolabs.fr
Tue Jun 30 08:48:14 PDT 2015
Hello,
I have to apologize for this issue.
The installation documentation, is not up-todate. Indeed, now ZOO-Kernel require you to run the make install command. Indeed we rely on lib_service.so (or dylib or dll) to run. So this library should be setup and available as any other in the LD_LIBRARY_PATH.
We are working on a new version of the documentation, which can be consulted here [1] and [2]. Note that this work is still ongoing so some informations may be missing. Please feel free to let us know if we forget anything in the documentation.
I hope you can confirm that running make instal solve your issue,
Best regards,
[1] http://zoo-project.org/docnew/docs/_build/html/
[2] http://zoo-project.org/workshops/_build/html/
> Le 30 juin 2015 à 17:25, Jo Cook <jocook at astuntechnology.com> a écrit :
> Hello,
> Today I have tried to compile ZOO from source using the instructions for Ubuntu here: http://www.zoo-project.org/docs/kernel/install-debian.html#debian-ubuntu
> I have followed the instructions exactly as they are written (check out source from subversion repo, build mapserver etc) and I got no obvious errors. One thing I did have to do before compiling cgic was create a symlink /usr/lib64/libfcgi.so pointing at /usr/lib/libfcgi.so as it didn't exist but after that it seemed to work just fine.
> When I come to test zoo_loader.cgi either in a web browser or at the command line I get the following error:
> /usr/lib/cgi-bin$ ./zoo_loader.cgi
> ./zoo_loader.cgi: error while loading shared libraries: libzoo_service.so.1.5: cannot open shared object file: No such file or directory
> (When I try this in a web browser I get the same error in the apache error log).
> I can see in the zoo-kernel folder that a file libzoo_service.so is created, but not libzoo_service.so.1.5.
> I previously tried this (about 3 weeks ago) on another machine, running Crunchbang linux 64 bit (which normally accepts ubuntu instructions without any problems) and it failed with the same error.
> Can anyone help me with this?
> Thanks
> Jo
> Jo Cook
> Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
> t:+44 7930 524 155
> iShare - Data integration and publishing platform
> Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss
