[Zoo-discuss] ZOO and Mapserver 6.4
Fenoy Gerald
gerald.fenoy at geolabs.fr
Thu Nov 5 01:26:20 PST 2015
Dear Luca,
thanks a lot for coming back on this topic.
I’ve discussed the issue I faced when passing to 7.0 with Thomas during the foss4g in Seoul and he told me that now we have to initialize the map object with some initializing functions dedicated to allocate memory. Indeed from what I was able to try some months back the ZOO-Kernel failed due to segmentation violation which should be caused by a memory part which was not correctly initialized.
I will try to upgrade to MapServer 7.0 on a VM and will let you know what are the result.
Best regards,
> Le 5 nov. 2015 à 09:33, Luca Delucchi <lucadeluge at gmail.com> a écrit :
> On 28 January 2014 at 11:12, Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
>> Dear Luca,
> Dear Gerald,
> I'm back on this topic
>> you should try using the following:
>>> MS_LDFLAGS=/home/lucadelu/compilati/mapserver-6-4-1/build/libmapserver.so
>> You kept the « -L » in what you gave initially.
>> For the CFLAGS, I’m not sure this is correct as you said that you built Mapserver in some other place, so the "-I/home/lucadelu/compilati/mapserver-6-4-1/" should point to the location where MapServer was built.
>>> MS_CFLAGS=-DUSE_MS -I/home/lucadelu/compilati/mapserver-6-4-1/
> any news to compile zoo against mapserver 6.4.1? or in the worst case
> did you try with mapserver 7?
>> Hope this helps,
>> Best regards,
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss
