[Zoo-discuss] keep the empty cache
pablo zader
pzader at gmail.com
Mon Nov 9 11:20:50 PST 2015
hello Fenoy,
So I think that the best solution for my case is the global definition, as
they are simple to layers consultations. If I had different requirements,
they could enable them locally for service, for example, if I wanted to
chain. This solution you propose, already implemented in zoo?
Best regards
Pablo
2015-11-03 10:23 GMT-03:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hello Venka,
> indeed that was it.
> So Pablo, the original idea was to define a life time for the cache and
> this can be defined in the ZCFGs for each service individually, obviously
> we may think also of a global definition in the main.cfg file for, let say
> a default life time. I would like to propose the following:
> in the main.cfg file in the main section add a lifetime key which can take
> the following values:
> * XXh meaning that after XX hours the cached file will be removed
> * XXm meaning that after XX minutes the cached file will be removed
> I suppose that it is not required to go under the minutes as it means in
> such a case that you don’t want to cache anything, in such a case you
> simply have to remove the cacheDir key from your main section then the
> ZOO-Kernel will not cache anything.
> For the ZOO-Services and their corresponding ZCFG I propose to use the
> same syntaxe as previously presented. The rule would be that, if there is
> something defined in the ZCFG then the main.cfg is not taken into account,
> in other case the main.cfg value will be taken as default.
> I hope to hear back from you Pablo to know if this solution may fits your
> needs.
> Best regards,
> > Le 1 nov. 2015 à 02:11, Venkatesh Raghavan <
> raghavan at media.osaka-cu.ac.jp> a écrit :
> > Hi Gerald and All,
> > On 2015/11/01 6:29, Fenoy Gerald wrote:
> >> Hi Pablo,
> >> I do apologize for so late reply, I was busy presenting the MapMint 2.0
> product during one week of training here in Senegal. This is the main cause
> of the late reply, in fact I just read your email right now…
> > I see that you had a great Training Session at Dakar and
> > that MapMint (which uses ZOO at its core) worked like
> > a charm. I saw some of the impressive maps that the participants
> > could publish during your training session.
> >> I remember having a huge discussion on this some years ago, I think it
> was with Farkas which was willing at that time to become a ZOO-Project
> developper but I cannot find the thread again, let me try to find it
> tomorrow when I will be back to my home town and I will go back to you.
> > I think the mail below from Farkas was the one your were searching
> > https://lists.osgeo.org/pipermail/zoo-discuss/2013-March/000940.html
> > Best
> > Venka
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20151109/d15e8649/attachment.html>
More information about the Zoo-discuss
