[Zoo-discuss] request and service MissingParameterValue error
Adrien ANDRÉ
adr.andre at laposte.net
Tue Oct 20 03:43:40 PDT 2015
I found the clue in apache access logs:
"GET /cgi-bin/wps/call/GetStatus/b2e197fa-7716-11e5-92c7-928d4e8d96f5
HTTP/1.1" 400 922 "-" "Mozilla/5.0 QGIS/2.8.1-Wien"
yes, no parameters here...
Le 20/10/2015 09:53, Adrien ANDRÉ a écrit :
> Dear list,
> after zoo-kernel and Status Service installation,
> writing a simple Python service with the following configuration:
> [raster]
> Title = Raster test.
> Abstract = Test service returning input raster.
> processVersion = 1
> storeSupported = true
> statusSupported = true
> serviceType = Python
> serviceProvider = raster
> <DataInputs>
> [inimage]
> Title = Input Image
> Abstract = Input image as a GeoTIFF file
> minOccurs = 1
> maxOccurs = 1
> <ComplexData>
> <Default>
> mimeType = image/tiff
> </Default>
> </ComplexData>
> </DataInputs>
> <DataOutputs>
> [outimage]
> Title = Output raster
> Abstract = Input raster copy
> <ComplexData>
> <Default>
> </Default>
> </ComplexData>
> </DataOutputs>
> and code:
> import zoo
> def raster(conf, inputs, outputs):
> import sys
> sys.stderr.write("Raster service start.")
> srcRasterFileName = inputs['inimage']['value']
> outputs["outimage"]["value"] = srcRasterFileName
> sys.stderr.write("Raster service end.")
> return zoo.SERVICE_SUCCEEDED
> when providing a sample raster file with QGIS WPS Plugin, i get this error:
> <?xml version="1.0" encoding="utf-8"?>
> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="fr-FR" version="1.1.0">
> <ows:Exception exceptionCode="MissingParameterValue" locator="request">
> <ows:ExceptionText>Mandatory parameter <request> was not
> specified</ows:ExceptionText>
> </ows:Exception>
> <ows:Exception exceptionCode="MissingParameter" locator="service">
> <ows:ExceptionText>Mandatory parameter <service> was not
> </ows:Exception>
> </ows:ExceptionReport>
> while Apache logs remain empty.
> I guess i missed something. Would you know where this comes from?
> Thanking you in advance,
> regards,
> Adrien André
More information about the Zoo-discuss
