[Zoo-discuss] Fwd: Installation of Zoo in Windows 10
Fenoy Gerald gerald.fenoy at geolabs.fr
Thu Jun 23 01:36:34 PDT 2016
Dear Anju,
thanks for trying to use the ZOO-Project on your windows platform.
The error you have means that something went wrong during the configuration of your IIS from the installer.
I would like to invite you to try the following commands: [1]. It contains all the command which should be run from the installer, you may have noticed that the last line of the commands has been added few weeks ago so it may explain why this was missing in the installer at that time. So first I would try this command from a cmd run as administrator:
appcmd.exe set config /section:isapiCgiRestriction /+[path='c:\inetpub\cgi-bin\zoo_loader.cgi',description='ZOO-Project',allowed='True']
I hope this helps and you can confirm that it solved you issue.
Best regards,
[1] http://www.zoo-project.org/docs/install/windows.html#install-by-hand
> Le 23 juin 2016 à 08:53, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> Dear All,
> I have just started exploring zoo and it's WPS features for GIS projects.But after installation in IIS 10 and Python  2.7 using Zoo Installer for Windows(32 bit Windows10), I am getting the following error:-
> POST http://localhost/cgi-bin/zoo_loader.cgi   405 Method Not Allowed
> Can you please tell me what could be the possible reason for this?
> Anju Bajpai
> RRSC-C
> Nagpur
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
