[Zoo-discuss] Fwd: Installation of Zoo in Windows 10
Anju Bajpai bajpai.anju at gmail.com
Thu Jun 23 02:20:31 PDT 2016
Dear Fenoy,
Thankyou for giving a quick reply.I have run the command given by you but
it is giving message as "ERROR ( message:New add object missing required
attributes. Cannot add duplicate collection entry of type 'add' with unique
key attribute 'path' set to 'c:\inetpub\cgi-bin\zoo_loader.cgi'. By the way
what is the mime type for CGI in IIS 10 Windows 10? I have added it as
Filename Extension = ".cgi" MIME Type:-"magnus-internal/cgi"
On Thu, Jun 23, 2016 at 2:06 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
wrote:
> Dear Anju,
> thanks for trying to use the ZOO-Project on your windows platform.
> The error you have means that something went wrong during the
> configuration of your IIS from the installer.
> I would like to invite you to try the following commands: [1]. It contains
> all the command which should be run from the installer, you may have
> noticed that the last line of the commands has been added few weeks ago so
> it may explain why this was missing in the installer at that time. So first
> I would try this command from a cmd run as administrator:
> appcmd.exe set config /section:isapiCgiRestriction
> /+[path='c:\inetpub\cgi-bin\zoo_loader.cgi',description='ZOO-Project',allowed='True']
> I hope this helps and you can confirm that it solved you issue.
> Best regards,
> [1] http://www.zoo-project.org/docs/install/windows.html#install-by-hand
> > Le 23 juin 2016 à 08:53, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > Dear All,
> > I have just started exploring zoo and it's WPS features for GIS
> projects.But after installation in IIS 10 and Python  2.7 using Zoo
> Installer for Windows(32 bit Windows10), I am getting the following error:-
> > POST http://localhost/cgi-bin/zoo_loader.cgi   405 Method Not Allowed
> > Can you please tell me what could be the possible reason for this?
> > Anju Bajpai
> > RRSC-C
> > Nagpur
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160623/8c679d19/attachment.html>
More information about the Zoo-discuss mailing list
