[Zoo-discuss] tmpPath and tmpUrl
Fenoy Gerald gerald.fenoy at geolabs.fr
Tue Jun 28 03:13:40 PDT 2016
Dear Rakesh,
sorry for late reply.
I am not sure to understand the issue here. May I ask, if you have set your generated_file to « /tmp/outFile.tif » as it should be ?
In case you have used outFile.tif, then, the ZOO-Kernel will be unable to find the file.
I hope this helps.
Best regards,
> Le 24 juin 2016 à 17:00, rakesh prithiviraj <rakeshuk at outlook.com> a écrit :
> Hi,
> I have the following config in my main.cfg file.
> tmpPath=/tmp/
> tmpUrl = http://192.168.3.86/zoo
> I also have a WPS service that creates output product outfile.tif in /tmp. In the service configuraion, asReference is set to true and in the service, I am using "generated_file" key to point to the output file.
> After the service execution, in the WPS response I am getting the URL of the file as
> http://192.168.3.86/zoo/le.tif
> the first 5 characters of the outfile name is dropped. If I change the parameter tmpPath from /tmp/ (5 characters) to /tmp (4 characters), I am getting http://192.168.3.86/zoo/ile.tif in the WPS response as URL. It looks like the length of value of tmpPath has impact on the response URL. I would expect http://192.168.3.86/zoo/outFile.tif as the response.
> could you please let me know how to fix this?
> regards
> Rakesh
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
