[Zoo-discuss] Update of database tables
rakesh prithiviraj rakeshuk at outlook.com
Wed Jun 29 07:59:04 PDT 2016
For an asynchronous WPS execute request, I observe that the status of the job under column "fstate" in "services" table does not show "running" when the service is still running. Instead it is blank. but after the job is successfully completed, the status changes to "succeeded".  As soon as i submit the WPS execute request, a new entry is created in the table but with no value for "fstate".
Is this configuration issue?
Also I would like to know when the "files" table is updated. My async WPS job produces files and in the getResult I could see valid reference URL to the file but the "files" table in the database is always empty.
 <wps:Output id="out1">    <wps:Reference href="http://192.168.3.86/ftep-output/f7177d10-3e06-11e6-bca9-005056011a8d/outDir/concatenated-files.txt" mimeType="application/text" encoding="UTF-8"/>  </wps:Output>
Thanks,Rakesh
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160629/5dcb2992/attachment.html>
More information about the Zoo-discuss mailing list
