[Zoo-discuss] ZOO-Project 1.6.0 on next OSGeoLiveDVD release
Fenoy Gerald gerald.fenoy at geolabs.fr
Mon May 29 08:03:19 PDT 2017
Hi Luca,
thanks a ton for your help.
In fact as you have noticed if you have tried the latest OSGeoLiveDVD version available online 10.5, that the demos applications available for use within OsgeoLiveDVD are the following:
 * OGR spatial tools [1]
 * CGAL triangulations [2]
 * OTB applications [3]
So we would need to illustrate the demo UI and explain briefly how to sue them.
For the GRASS demo, I think we should first create the demo UI on the web site then decide wether we should include it into OSGeoLiveDVD or not.
In case, you already have in mind some demo application for GRASS then we can discuss this there and get it working on the web site.
Still, by now we should keep focus on the documentation update for the OSGeoLiveDVD in other case we will be removed from there which is very bad IMO.
Best regards,
[1] http://www.zoo-project.org/examples/spatialtools.html
[2] http://www.zoo-project.org/examples/cgal.html
[3] http://www.zoo-project.org/examples/otb-example.html
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
> Le 23 mai 2017 à 22:45, Luca Delucchi <lucadeluge at gmail.com> a écrit :
> On 15 May 2017 at 10:48, Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
>> Dear all,
> Dear Gerald,
>> I come to y ou to know if anybody would be available to help in updating the documentation for the ZOO-Project on OSGeoLiveDVD.
>> Indeed, the documentation is outdated in the sense that from the previous release we  have added a landing page presenting links to local exemple UI that give access to the same demo as the one available on the website [1].
>> The demo available on OSGeoLiveDVD can be accessed from the ZOO-Project item in the start > gis > web services submenu.
>> The documentation present only the OGR Spatial Tools exemple when it should present briefly all the demonstration interfaces.
>> Note that the deadline for achieving this is on June 5th so we need feedbacks soon.
> I can help.
> I could spend half/one day next week on it, but I would like to work
> with someone else also because I'm using ZOO less then before and I
> don't know at all the latest versions...
> I could also help on GRASS GIS services for [1]
>> I hope to hear from you.
>> Best regards,
>> [1] http://www.zoo-project.org/Resources/Examples
> ciao
> Luca
> www.lucadelu.org
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
