[Zoo-discuss] Adding Orfeo Toolbox and SAGA GIS support to ZOO Project on Windows 10
MAYANK JASORIA f2016703 at pilani.bits-pilani.ac.in
Tue Jul 3 23:57:35 PDT 2018
Greetings to all
I still haven't had any success with this issue. even when I try to work on
adding SAGA GIS support, I get the following error:
process_begin: CreateProcess(NULL, uname -s, ...) failed.
mingw32-make: ../../zoo-project/zoo-kernel/ZOOMakefile.opts:10: pipe: No
error
`wx-config --cxx` @SAGA_CPPFLAGS@ `wx-config --cxxflags`
-I../../zoo-project/../thirds/cgic206/ -I../../zoo-project/zoo-kernel/
@XML2_CPPFLAGS@ @GDAL_CFLAGS@ @PYTHON_CPPFLAGS@ -DLINUX_FREE_ISSUE  -fpic
-o saga2zcfg ./saga2zcfg.c @GDAL_LIBS@   `wx-config --libs` @SAGA_LDFLAGS@
process_begin: CreateProcess(NULL, `wx-config --cxx` @SAGA_CPPFLAGS@
`wx-config --cxxflags` -I../../zoo-project/../thirds/cgic206/
-I../../zoo-project/zoo-kernel/ @XML2_CPPFLAGS@ @GDAL_CFLAGS@
@PYTHON_CPPFLAGS@ -DLINUX_FREE_ISSUE -fpic -o saga2zcfg ./saga2zcfg.c
@GDAL_LIBS@ `wx-config --libs` @SAGA_LDFLAGS@, ...) failed.
make (e=2): The system cannot find the file specified.
mingw32-make: *** [Makefile:11: saga2zcfg] Error 2
I am still struggling due to unavailability of proper documentation for
windows in this regard, both for Orfeo Toolbox and for SAGA GIS.
I request you all to kindly look into this and help.
Thanks.
On Wed, Jun 27, 2018 at 11:12 AM, MAYANK JASORIA <
f2016703 at pilani.bits-pilani.ac.in> wrote:
> Dear all,
> I have been trying to add Orfeo Toolbox support and SAGA GIS support to
> ZOO Project on Windows 10. ZOO Project was installed using the installer.
> The official documentation only covers the addition of this support on
> Ubuntu.
> Even so, I did try to add Orfeo Toolbox support by running the given
> commands on command prompt in the zoo-project-1.5.0 folder from the ZIP
> file. (I installed Orfeo Toolbox using the installer form the official
> website)
> To add the required commands I installed MinGW64 and set its bin to my
> path variables and also installed cmake. The required makefile was then
> generated using cmake-gui .. (alternative to ccmake .. command).
> While executing the make (mingw32-make) command, I am getting a "cannot
> open source file /bigobg : No such file or directory".
> Someone please help me with the process. Also, it would be great if there
> was proper documentation on how to add orfeo toolbox and SAGA GIS support
> for windows, especieally if package installer was used to install ZOO
> Project.
> Thanks.
> ᐧ
ᐧ
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20180704/57ccd0c7/attachment.html>
More information about the Zoo-discuss mailing list
