[Zoo-discuss] Adding Orfeo Toolbox and SAGA GIS support to ZOO Project on Windows 10
Gérald Fenoy gerald.fenoy at geolabs.fr
Wed Jul 4 02:54:48 PDT 2018
Dear Mayank,
I have to admit that I never tried to use the OrfeoToolBox or SAGA-GIS support on windows platform. So, I guess you may face many issues in trying to build this support on windows.
Note that the latest version I currently use for building the ZOO-Project is from the branch prototype-v0 [1] which contains the latest source code enhancements. Nevertheless, if I was able to build this branch on windows [2] I was not able to run it properly till now...
In case you need to build a new version of the ZOO-Project, I think the best way to go is to use the AppVeyor system which ease maintenance and sharing of informations / logs about building procedures.
For instance, from the AppVeyor sample I provided, you may create your own AppVeyor project and build in the same way I currently build the ZOO-Project (and other tools required by MapMint) on your own. You can also add the steps required to build and/or install OrfeoToolBox in the build script to finally try to build the OrfeoToolBox support from here. You may proceed in the same way to add the SAGA-GIS support.
It would be great to give a push for the Windows support. Nevertheless, there is nothing planed about this effort yet.
Best regards,
[1] http://www.zoo-project.org/trac/browser/branches/prototype-v0
[2] https://ci.appveyor.com/project/djay/trunk/build/1.6.0-184
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
> Le 27 juin 2018 à 07:42, MAYANK JASORIA <f2016703 at pilani.bits-pilani.ac.in> a écrit :
> Dear all,
> I have been trying to add Orfeo Toolbox support and SAGA GIS support to ZOO Project on Windows 10. ZOO Project was installed using the installer. The official documentation only covers the addition of this support on Ubuntu.
> Even so, I did try to add Orfeo Toolbox support by running the given commands on command prompt in the zoo-project-1.5.0 folder from the ZIP file. (I installed Orfeo Toolbox using the installer form the official website)
> To add the required commands I installed MinGW64 and set its bin to my path variables and also installed cmake. The required makefile was then generated using cmake-gui .. (alternative to ccmake .. command).
> While executing the make (mingw32-make) command, I am getting a "cannot open source file /bigobg : No such file or directory".
> Someone please help me with the process. Also, it would be great if there was proper documentation on how to add orfeo toolbox and SAGA GIS support for windows, especieally if package installer was used to install ZOO Project.
> Thanks.
> ᐧ
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
