[Zoo-discuss] Problem in the ZOO WPS process generation
Pablo J. Zader pzader at gmail.com
Sat Aug 24 17:12:07 PDT 2019
HI list
Trying generate process wps, raise this error and can't understand wheres
is the problem:
(the procedure here:
https://code.google.com/archive/p/wps-grass-bridge/wikis/ZOO_WPS_Integration.wiki
GRASS 7.6.2dev (gfs):/opt/wps-grass-bridge/trunk > sudo python
GrassXMLtoZCFG.py -x gms/Testing/Python/XML/r.univar.xml -z
zoo_services/r_univar.zcfg -p r_univar.py
  File "GrassXMLtoZCFG.py", line 28, in <module>
    import wpsXML.WPS_1_0_0.OGC_WPS_1_0_0 as wps
  File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/OGC_WPS_1_0_0.py",
line 18, in <module>
    import _ows
  File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_ows.py", line 19, in
<module>
    import _xlink
  File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_xlink.py", line 22,
in <module>
    ModuleRecord._setModule(sys.modules[__name__])
AttributeError: 'ModuleRecord' object has no attribute '_setModule'
 CHeers
Pablo
Pablo J. Zader
Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de Alerta y
Respuesta Temprana a Emergencias
pablo.zader at gmail.com
Universidad Nacional de Córdoba
Av. Valpáraíso s/n Ciudad Universitaria
 [image: skype] [image: linkedIn]
<http://linkedin.com/in/pablo-javier-zader-7a232125>
*"Los Grandes Hombres hablan sobre ideas...  Los Hombres Promedio hablan
sobre cosas...  Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahí? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20190824/2ade7ada/attachment.html>
More information about the Zoo-discuss mailing list
