[Zoo-discuss] Problem in the ZOO WPS process generation
Luca Delucchi
lucadeluge at gmail.com
Mon Aug 26 08:20:25 PDT 2019
On Sun, 25 Aug 2019 at 02:12, Pablo J. Zader <pzader at gmail.com> wrote:
> HI list
> Trying generate process wps, raise this error and can't understand wheres
> is the problem:
> (the procedure here:
> https://code.google.com/archive/p/wps-grass-bridge/wikis/ZOO_WPS_Integration.wiki
> GRASS 7.6.2dev (gfs):/opt/wps-grass-bridge/trunk > sudo python
> GrassXMLtoZCFG.py -x gms/Testing/Python/XML/r.univar.xml -z
> zoo_services/r_univar.zcfg -p r_univar.py
> Traceback (most recent call last):
> File "GrassXMLtoZCFG.py", line 28, in <module>
> import wpsXML.WPS_1_0_0.OGC_WPS_1_0_0 as wps
> File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/OGC_WPS_1_0_0.py",
> line 18, in <module>
> import _ows
> File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_ows.py", line 19, in
> <module>
> import _xlink
> File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_xlink.py", line 22,
> in <module>
> ModuleRecord._setModule(sys.modules[__name__])
> AttributeError: 'ModuleRecord' object has no attribute '_setModule'
the problem is not related to ZOO but to the grass bridge, I will try to
open an issue in the site you mentioned before.
(however the bridge should be updated to python3 otherwise it will not work
anymore)
> CHeers
> Pablo
ciao
Luca
www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20190826/f93645c7/attachment.html>
More information about the Zoo-discuss
