[Zoo-discuss] Problem in the ZOO WPS process generation
Pablo J. Zader pzader at gmail.com
Sat Aug 31 09:27:08 PDT 2019
Hi Lica
You're right, the problem is not with "zoo". Thanks for answering.
I somehow made it work but I don't remember how, I will try to retrace my
steps to inform
Regards
El lun., 26 ago. 2019 a las 12:20, Luca Delucchi (<lucadeluge at gmail.com>)
escribió:
> On Sun, 25 Aug 2019 at 02:12, Pablo J. Zader <pzader at gmail.com> wrote:
>> HI list
> Hi,
>> Trying generate process wps, raise this error and can't understand wheres
>> is the problem:
>> (the procedure here:
>> https://code.google.com/archive/p/wps-grass-bridge/wikis/ZOO_WPS_Integration.wiki
>> GRASS 7.6.2dev (gfs):/opt/wps-grass-bridge/trunk > sudo python
>> GrassXMLtoZCFG.py -x gms/Testing/Python/XML/r.univar.xml -z
>> zoo_services/r_univar.zcfg -p r_univar.py
>> Traceback (most recent call last):
>>   File "GrassXMLtoZCFG.py", line 28, in <module>
>>     import wpsXML.WPS_1_0_0.OGC_WPS_1_0_0 as wps
>>   File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/OGC_WPS_1_0_0.py",
>> line 18, in <module>
>>     import _ows
>>   File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_ows.py", line 19,
>> in <module>
>>     import _xlink
>>   File "/opt/wps-grass-bridge/trunk/wpsXML/WPS_1_0_0/_xlink.py", line 22,
>> in <module>
>>     ModuleRecord._setModule(sys.modules[__name__])
>> AttributeError: 'ModuleRecord' object has no attribute '_setModule'
> the problem is not related to ZOO but to the grass bridge, I will try to
> open an issue in the site you mentioned before.
> (however the bridge should be updated to python3 otherwise it will not
> work anymore)
>>  CHeers
>> Pablo
> ciao
> Luca
> www.lucadelu.org
Pablo J. Zader
Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de Alerta y
Respuesta Temprana a Emergencias
pablo.zader at gmail.com
Universidad Nacional de Córdoba
Av. Valpáraíso s/n Ciudad Universitaria
 [image: skype] [image: linkedIn]
<http://linkedin.com/in/pablo-javier-zader-7a232125>
*"Los Grandes Hombres hablan sobre ideas...  Los Hombres Promedio hablan
sobre cosas...  Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahí? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20190831/5bd9b8e6/attachment.html>
More information about the Zoo-discuss mailing list
