[Zoo-discuss] OGC API - Processing tentative implementation
Pablo J. Zader
pzader at gmail.com
Tue Oct 8 14:03:49 PDT 2019
Hi Gerald
Great job! Congratulations!
To better understand the incorporation of the API, instead of invoking the
processes through the traditional way, now we can do it using the API?
For example,
If I have a service which is executed in this way: ( myprocess: x -> y)
http://localhost/cgi-bin/zoo_proyect?service=wps&request=execute&identifier=
*myprocess*..%DataInputs=*x*=...; output=*y*...
using the API, how should I invoke it?
Regards
Pablo
El vie., 6 sept. 2019 a las 7:49, Gérald Fenoy (<gerald.fenoy at geolabs.fr>)
escribió:
> Dear all,
> I would like to let you know that yesterday I have finally committed in
> r949 [1] the first tentative implementation of the ongoing « OGC API -
> Processing » (which I should probably name wps-rest-binding by now, or WPS
> 3 when it will be accepted) which was discussed during the OGC Hackathon in
> London late June this year.
> After coming back from the Hackathon, I have published this very small
> report [2] presenting how to use the OGC API for processing with
> ZOO-Project.
> From my testing it is working properly but with some limitations:
> * inputs are not validated yet, meaning that in case the request did not
> contain a value for an input, your service will still be invoked (note that
> this feature can be activated again by modifying the validation function),
> * no MapServer output support for OGC API - Processing cause I suppose
> that we should wait for OGC API - Features support in MapServer (I was
> thinking that outputting WMS, WFS and WCS from previous standard versions
> do not make sens as we use the new processing api), note that there should
> not be any issue in activating this support again.
> The documentation has been updated to provide informations about the new
> oas.cfg file used for OpenAPI Specification [3] and the configuration
> options to activate this support [4].
> I hope you will have great time testing this new WPS REST Binding.
> Best regards,
> [1] http://www.zoo-project.org/trac/changeset/949
> [2] http://www.zoo-project.org/trac/wiki/OGC_Hackathon_2019
> [3]
> http://www.zoo-project.org/docs/kernel/configuration.html#openapi-specification-configuration-file
> [4]
> http://www.zoo-project.org/docs/install/installation.html#ogc-api-processing-support-optional
> Gerald Fenoy
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
Pablo J. Zader
Lic. en Cs. de la Computación + MSc. en Aplicaciones Espaciales de Alerta y
Respuesta Temprana a Emergencias
pablo.zader at gmail.com
Universidad Nacional de Córdoba
Av. Valpáraíso s/n Ciudad Universitaria
[image: skype] [image: linkedIn]
<http://linkedin.com/in/pablo-javier-zader-7a232125>
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahí? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20191008/730749e1/attachment.html>
More information about the Zoo-discuss
