[Zoo-discuss] ZOO-Project 1.8.0 release candidate 1
Gérald Fenoy gerald.fenoy at geolabs.fr
Fri Dec 18 11:36:51 PST 2020
Dear all,
As decided during the last PSC meeting, we are glad to present the new released version of the ZOO-Project!
This new release contains new features and fixes.
Amongst new features, we can quote the docker-compose environment created by Samuel Souk-Aloun which offer to deploy the ZOO-Project with few very simple services. We may also refer to the new support of the OGC API - Processes. Indeed, this version offers a preview of the current, slightly modified, standard as discussed at OGC. Also, with this new OGC API - Processes comes support a specific basic web user interface that let the user browse and execute services.
Main new features and fixes :
  * Support raw response in OGC API - Processes
  * Add a ZOO-API section to the howtos documentation
  * OGC API - Processes support:
  https://github.com/gfenoy/wps-rest-binding/tree/change-request/95
  * Support two inputs/outputs syntaxes discussed (using json object
  or array of json object) for ZOO-Kernel and the HTML client
  * Fix issue in kvParseInput when memory!=load and handle session
  from the OGC API - Processes
  * Update OGC API - Processes documentation
  * Add open-api directory in utils services containing a reddis
  subscription example, the HTML UI and the display service using
  Cheetah templating system
  * Update the oas.cfg file to reflect new api definition
  * Include basic microdata in the HTML home page
  * Add HTML support for basic interractions with OGC API - Processes
  including execution of service from the service-desc link
  * OGC API - Processes added support for syncrhonous Execute requests
  * Reuse service_callback in OGC API - Processes when subscriber
  object is provided in the JSON request
  * OGC API - Processes implementation as available on 2020-10-19
  * Produce value string only when memory=load for Python support.
  * Make local files uris usable when cache is used
  * Make GDAL/profile service usable in case memory=protect
  * Add Dockerfile and docker-compose environment with pgbouncer, see #177
  * Add documentation on how to use asyncrhonous execution using the Javascript
  ZOO-API
  * Start simplification of the runRequest function
  * Integrate optional support for OGC API - Processing implementation
  * Add the optional handleText parameter to provide pure text for
  complex data node with mimetype="text/*"
  * Fix issue in case !JavaScript support is activated
  * Fix issue with GDAL profile service
  * Fix #172 for https support
I hope you will have great time using this new version and we will wait for your feedbacks.
Best wishes,
Gerald Fenoy
Chair, ZOO-Project PSC
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20201218/194d586c/attachment.html>
More information about the Zoo-discuss mailing list
