Gérald Fenoy wrote: > Note that I'm not sure it's a problem, as they do the work,they get > right to communicate as if they did it, isn't it ? > It's no problem at all if you call it the LisaSoftDVD. It is a problem if you call it the OSGeo LiveDVD. -jeff
