[ZOO-PSC] ZOO-Project release 1.4.0-rc1
Fenoy Gerald
gerald.fenoy at geolabs.fr
Thu Nov 20 03:25:09 PST 2014
Dear ZOO-Project users,
I am please to announce the ZOO-Project 1.4.0 first release candidate [1].
This release should work correctly on both GNU/Linux, MacOS X and WIN32 platforms.
You can download the archives from [2] (zip) and [3] (tar.bz2) or use Subversion:
svn co http://svn.zoo-project.org/svn/tags/rel-1.4.0-rc1/ zoo-project-1.4.0-rc1
The most important modifications / fixes are listed below:
* Binary support for PHP language
* ZOO-API for the Java language
* ZOO-Client Javascript API
* FastCGI fixes
* JavaScript ZOO-API enhancements (COOKIE use and Output in generated XML)
* Add debian files
* Inputs passed by reference downloaded in parallel
* Conform behavior for DescribeProcess when the Identifier was not found
* Add support of maximumMegabytes keywords for ComplexData Inputs
* Add the optional YAML ZCFG support #4 and the zcfg2yaml converter
* Return error messages that enable the service provider to quickly identify the root cause of errors due to configuration file syntax (ticket #90)
* Fix logic in addMapToMap (ticket #91)
* Enable AllowedValue and multiple Range definitions using default and supported blocks
* Add the lastest revision number in version.h (available in Python ZOO-API)
* Add the optional Ruby Language Support to the ZOO-Kernel with an API similar to the Python ZOO-API
* Small rewrite of Python support
* Inputs can be requested over https protocol (ticket #86)
* Add capability to define both percentage of execution and a message (ticket #87).
* Add usid in lenv section used to generate an unique identifier based on time and the process identifier.
* Add gdal_contour service
* Add dynamic definition of serverAddress from the main section
As we did for previous release, we will now wait for feedbacks for a period of 7 days before releasing the 1.4.0 release.
This work was supported by a grant from the European Union's 7th Framework Programme (2007-2013) provided for the project PublicaMundi (GA no. 609608).
I hope to hear back from you,
Best regards,
Gérald Fenoy
ZOO-PSC Chair
[1] http://www.zoo-project.org/site/Downloads#ZOO-Projectversion1.4.0
[2] http://zoo-project.org/dl/zoo-project-1.4.0-rc1.zip
[3] http://zoo-project.org/dl/zoo-project-1.4.0-rc1.tar.bz2
More information about the Zoo-psc
