[ZOO-PSC] [Zoo-discuss] ZOO-Project release 1.4.0-rc1
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Thu Nov 20 04:33:56 PST 2014
Gerald and All,
Great work and good timing. Hope to learn more ZOO-Tricks
at FOSS4G-Asia [1].
Also, would like to announce that ZOO-Project team will participate
a Code-Sprint Session at FOSS4G-Asia that is scheduled for
5 Dec 2014 [2]
Best
Venka
[1] http://www.foss4g-asia.org/2014/
[2] http://www.foss4g-asia.org/2014/programmenu/conference-seminar-agenda/
On 2014/11/20 20:25, Fenoy Gerald wrote:
> Dear ZOO-Project users,
> I am please to announce the ZOO-Project 1.4.0 first release candidate [1].
> This release should work correctly on both GNU/Linux, MacOS X and WIN32 platforms.
> You can download the archives from [2] (zip) and [3] (tar.bz2) or use Subversion:
> svn co http://svn.zoo-project.org/svn/tags/rel-1.4.0-rc1/ zoo-project-1.4.0-rc1
> The most important modifications / fixes are listed below:
> * Binary support for PHP language
> * ZOO-API for the Java language
> * ZOO-Client Javascript API
> * FastCGI fixes
> * JavaScript ZOO-API enhancements (COOKIE use and Output in generated XML)
> * Add debian files
> * Inputs passed by reference downloaded in parallel
> * Conform behavior for DescribeProcess when the Identifier was not found
> * Add support of maximumMegabytes keywords for ComplexData Inputs
> * Add the optional YAML ZCFG support #4 and the zcfg2yaml converter
> * Return error messages that enable the service provider to quickly identify the root cause of errors due to configuration file syntax (ticket #90)
> * Fix logic in addMapToMap (ticket #91)
> * Enable AllowedValue and multiple Range definitions using default and supported blocks
> * Add the lastest revision number in version.h (available in Python ZOO-API)
> * Add the optional Ruby Language Support to the ZOO-Kernel with an API similar to the Python ZOO-API
> * Small rewrite of Python support
> * Inputs can be requested over https protocol (ticket #86)
> * Add capability to define both percentage of execution and a message (ticket #87).
> * Add usid in lenv section used to generate an unique identifier based on time and the process identifier.
> * Add gdal_contour service
> * Add dynamic definition of serverAddress from the main section
> As we did for previous release, we will now wait for feedbacks for a period of 7 days before releasing the 1.4.0 release.
> This work was supported by a grant from the European Union's 7th Framework Programme (2007-2013) provided for the project PublicaMundi (GA no. 609608).
> I hope to hear back from you,
> Best regards,
> Gérald Fenoy
> ZOO-PSC Chair
> [1] http://www.zoo-project.org/site/Downloads#ZOO-Projectversion1.4.0
> [2] http://zoo-project.org/dl/zoo-project-1.4.0-rc1.zip
> [3] http://zoo-project.org/dl/zoo-project-1.4.0-rc1.tar.bz2
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-psc
