[ZOO-PSC] ZOO-Project 1.7.0 release
    nicolas bozon
    nicolas.bozon at gmail.com
    Sat Jun  1 02:15:41 PDT 2019
+1
Thank you Gérald for this great work
Best,
Nick
Le sam. 1 juin 2019 à 08:20, Massimiliano Cannata <
massimiliano.cannata at supsi.ch> a écrit :
> +1
> Greta Job as always ;-)
> Il Sab 1 Giu 2019 02:20 Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>
> ha scritto:
>> +1
>> Great to see all the new functionality and enhancements in 1.7.0.
>> Thanks Gerald for managing the release.
>> Best
>> Venka
>> On 6/1/2019 6:53 AM, Jeff McKenna wrote:
>> > +1
>> > Great news Gérald.  I will also package 1.7.0 for MS4W users, which I
>> > see from download statistics is very popular!
>> > -jeff
>> > On 2019-05-31 11:33 AM, Gérald Fenoy wrote:
>> >> Dear PSC members,
>> >> I would like to ask you to vote for releasing 1.7.0 version of the
>> >> ZOO-Project.
>> >> I suppose you have noticed the modifications that has been done over
>> >> the past few months. One the biggest was to merge prototype-v0 in
>> >> trunk [1] which was used during almost 2 years for developing the new
>> >> ZOO-Project version, including for example the R support and the HPC
>> >> one. Lately, we have made some tests for building for both GNU/Linux
>> >> [2] and Window [3] platforms using appVeyor free account.
>> >> Bellow, you can see a list of important modifications:
>> >>    * Fix issue with UOM definitions in zcfg2sql
>> >>    * Make callback and HPC support independent from each other
>> >>    * Update SAGA-GIS support to version 7.2.0
>> >>    * Add support for custom MapServer style definition for raster
>> output
>> >>    * Fix returned bbox definition #170
>> >>    * Store semaphore status in lenv section for future deletion
>> >>    * Update Windows support to newer compiler
>> >>    * Fix issue with UpdateStatus function from the Mono ZOO-API
>> >>    * Add logging functionality and other utility functions to the C-API
>> >>    * Return an exception for every output for which nb_pixel or
>> >>    nb_features is 0
>> >>    * Add a shared key to the security section to differentiate the
>> >>    referenced data
>> >>    * Add MapServer output style definition depending on the geometry
>> >>    type
>> >>    * Add ogr.tindex service
>> >>    * Add support for literaldata input arrays and to call services
>> >>    asyncrhonously from the JavaScript ZOO-API
>> >>    * Expose a sleep function to the JavaScript ZOO-API
>> >>    * Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
>> >>    sacct respectively
>> >>    * Store md5sum of the cached file (so, local to the WPS server) to
>> >>    compare before uploading (if different md5sum) on the HPC server
>> >>    * Add support for R language
>> >>    * Add support for using "file://"  for referenced data input
>> >>    * Add an optional ecookie key for returning third-party cookies
>> >>    * Fix issue when parsing BoundingBox input #163
>> >>    * Add memory key to the main section to force the ZOO-Kernel to load
>> >>    data into memory or use local file
>> >>    * Add the dialect input to the ogr2ogr service
>> >>    * Store the list of generated mapfiles in a file (cf DeleteData
>> >> service)
>> >>    * Define the correct MS_IMAGEMODE in the generated mapfile
>> >>    * Option to use MapServer support to publish heatmap
>> >>    * Add status_code key to the lenv for setting Status HTTP response
>> >> header
>> >>    * Add the Creation Option inputs to the Gdal_Dem service
>> >>    * Add prohibited key in the callback section to define a list of
>> >>    services not requiring any invocation
>> >>    * Produce zcfg for OTB applications using the correct default pixel
>> >> type
>> >>    * Add asynchronous callback invocation to send information about
>> >>    the ongoing services to a third-party software
>> >>    * Add mapsToJson, mapsToJson, and elementsToJson to the API
>> >>    * Provide a zcfg2sql tool to convert a zcfg metadata file to SQL
>> >> script
>> >>    * Add support to store service metadata information into a database
>> >>    * Add HPC Support for remote execution of SBATCH scripts through
>> Slurm
>> >>    * Add cookie reference to _HINTERNET
>> >>    * Support headers for GET requests from the js ZOO-API
>> >>    * Pass all headers listed in the attributes parameter from the
>> >>    [security] section to the hosts listed in the hosts parameter of the
>> >>    same section (ticket #139)
>> >> I am proposing myself as a release manager and the release to occur on
>> >> next Friday (2019/06/07).
>> >> My vote is obviously +1 for this release.
>> >> Best regards,
>> >> [1] http://www.zoo-project.org/trac/changeset/917
>> >> [2] https://ci.appveyor.com/project/djay/trunk-t67ri/builds/24881108
>> >> [3] https://ci.appveyor.com/project/djay/trunk-hp3tw/builds/24868734
>> > _______________________________________________
>> > Zoo-psc mailing list
>> > Zoo-psc at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/zoo-psc
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20190601/1f112d37/attachment-0001.html>
More information about the Zoo-psc
