[ZOO-PSC] ZOO-Project 1.7.0 release
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Fri May 31 17:20:33 PDT 2019
+1
Great to see all the new functionality and enhancements in 1.7.0.
Thanks Gerald for managing the release.
Best
Venka
On 6/1/2019 6:53 AM, Jeff McKenna wrote:
> +1
> Great news Gérald. I will also package 1.7.0 for MS4W users, which I
> see from download statistics is very popular!
> -jeff
> On 2019-05-31 11:33 AM, Gérald Fenoy wrote:
>> Dear PSC members,
>> I would like to ask you to vote for releasing 1.7.0 version of the
>> ZOO-Project.
>> I suppose you have noticed the modifications that has been done over
>> the past few months. One the biggest was to merge prototype-v0 in
>> trunk [1] which was used during almost 2 years for developing the new
>> ZOO-Project version, including for example the R support and the HPC
>> one. Lately, we have made some tests for building for both GNU/Linux
>> [2] and Window [3] platforms using appVeyor free account.
>> Bellow, you can see a list of important modifications:
>> * Fix issue with UOM definitions in zcfg2sql
>> * Make callback and HPC support independent from each other
>> * Update SAGA-GIS support to version 7.2.0
>> * Add support for custom MapServer style definition for raster output
>> * Fix returned bbox definition #170
>> * Store semaphore status in lenv section for future deletion
>> * Update Windows support to newer compiler
>> * Fix issue with UpdateStatus function from the Mono ZOO-API
>> * Add logging functionality and other utility functions to the C-API
>> * Return an exception for every output for which nb_pixel or
>> nb_features is 0
>> * Add a shared key to the security section to differentiate the
>> referenced data
>> * Add MapServer output style definition depending on the geometry
>> type
>> * Add ogr.tindex service
>> * Add support for literaldata input arrays and to call services
>> asyncrhonously from the JavaScript ZOO-API
>> * Expose a sleep function to the JavaScript ZOO-API
>> * Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
>> sacct respectively
>> * Store md5sum of the cached file (so, local to the WPS server) to
>> compare before uploading (if different md5sum) on the HPC server
>> * Add support for R language
>> * Add support for using "file://" for referenced data input
>> * Add an optional ecookie key for returning third-party cookies
>> * Fix issue when parsing BoundingBox input #163
>> * Add memory key to the main section to force the ZOO-Kernel to load
>> data into memory or use local file
>> * Add the dialect input to the ogr2ogr service
>> * Store the list of generated mapfiles in a file (cf DeleteData
>> service)
>> * Define the correct MS_IMAGEMODE in the generated mapfile
>> * Option to use MapServer support to publish heatmap
>> * Add status_code key to the lenv for setting Status HTTP response
>> header
>> * Add the Creation Option inputs to the Gdal_Dem service
>> * Add prohibited key in the callback section to define a list of
>> services not requiring any invocation
>> * Produce zcfg for OTB applications using the correct default pixel
>> type
>> * Add asynchronous callback invocation to send information about
>> the ongoing services to a third-party software
>> * Add mapsToJson, mapsToJson, and elementsToJson to the API
>> * Provide a zcfg2sql tool to convert a zcfg metadata file to SQL
>> script
>> * Add support to store service metadata information into a database
>> * Add HPC Support for remote execution of SBATCH scripts through Slurm
>> * Add cookie reference to _HINTERNET
>> * Support headers for GET requests from the js ZOO-API
>> * Pass all headers listed in the attributes parameter from the
>> [security] section to the hosts listed in the hosts parameter of the
>> same section (ticket #139)
>> I am proposing myself as a release manager and the release to occur on
>> next Friday (2019/06/07).
>> My vote is obviously +1 for this release.
>> Best regards,
>> [1] http://www.zoo-project.org/trac/changeset/917
>> [2] https://ci.appveyor.com/project/djay/trunk-t67ri/builds/24881108
>> [3] https://ci.appveyor.com/project/djay/trunk-hp3tw/builds/24868734
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
More information about the Zoo-psc
