[ZOO-PSC] ZOO-Project 1.7.0 release
    Massimiliano Cannata
    massimiliano.cannata at supsi.ch
    Fri May 31 23:20:13 PDT 2019
+1
Greta Job as always ;-)
Il Sab 1 Giu 2019 02:20 Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>
ha scritto:
> +1
> Great to see all the new functionality and enhancements in 1.7.0.
> Thanks Gerald for managing the release.
> Best
> Venka
> On 6/1/2019 6:53 AM, Jeff McKenna wrote:
> > +1
> > Great news Gérald.  I will also package 1.7.0 for MS4W users, which I
> > see from download statistics is very popular!
> > -jeff
> > On 2019-05-31 11:33 AM, Gérald Fenoy wrote:
> >> Dear PSC members,
> >> I would like to ask you to vote for releasing 1.7.0 version of the
> >> ZOO-Project.
> >> I suppose you have noticed the modifications that has been done over
> >> the past few months. One the biggest was to merge prototype-v0 in
> >> trunk [1] which was used during almost 2 years for developing the new
> >> ZOO-Project version, including for example the R support and the HPC
> >> one. Lately, we have made some tests for building for both GNU/Linux
> >> [2] and Window [3] platforms using appVeyor free account.
> >> Bellow, you can see a list of important modifications:
> >>    * Fix issue with UOM definitions in zcfg2sql
> >>    * Make callback and HPC support independent from each other
> >>    * Update SAGA-GIS support to version 7.2.0
> >>    * Add support for custom MapServer style definition for raster output
> >>    * Fix returned bbox definition #170
> >>    * Store semaphore status in lenv section for future deletion
> >>    * Update Windows support to newer compiler
> >>    * Fix issue with UpdateStatus function from the Mono ZOO-API
> >>    * Add logging functionality and other utility functions to the C-API
> >>    * Return an exception for every output for which nb_pixel or
> >>    nb_features is 0
> >>    * Add a shared key to the security section to differentiate the
> >>    referenced data
> >>    * Add MapServer output style definition depending on the geometry
> >>    type
> >>    * Add ogr.tindex service
> >>    * Add support for literaldata input arrays and to call services
> >>    asyncrhonously from the JavaScript ZOO-API
> >>    * Expose a sleep function to the JavaScript ZOO-API
> >>    * Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
> >>    sacct respectively
> >>    * Store md5sum of the cached file (so, local to the WPS server) to
> >>    compare before uploading (if different md5sum) on the HPC server
> >>    * Add support for R language
> >>    * Add support for using "file://"  for referenced data input
> >>    * Add an optional ecookie key for returning third-party cookies
> >>    * Fix issue when parsing BoundingBox input #163
> >>    * Add memory key to the main section to force the ZOO-Kernel to load
> >>    data into memory or use local file
> >>    * Add the dialect input to the ogr2ogr service
> >>    * Store the list of generated mapfiles in a file (cf DeleteData
> >> service)
> >>    * Define the correct MS_IMAGEMODE in the generated mapfile
> >>    * Option to use MapServer support to publish heatmap
> >>    * Add status_code key to the lenv for setting Status HTTP response
> >> header
> >>    * Add the Creation Option inputs to the Gdal_Dem service
> >>    * Add prohibited key in the callback section to define a list of
> >>    services not requiring any invocation
> >>    * Produce zcfg for OTB applications using the correct default pixel
> >> type
> >>    * Add asynchronous callback invocation to send information about
> >>    the ongoing services to a third-party software
> >>    * Add mapsToJson, mapsToJson, and elementsToJson to the API
> >>    * Provide a zcfg2sql tool to convert a zcfg metadata file to SQL
> >> script
> >>    * Add support to store service metadata information into a database
> >>    * Add HPC Support for remote execution of SBATCH scripts through
> Slurm
> >>    * Add cookie reference to _HINTERNET
> >>    * Support headers for GET requests from the js ZOO-API
> >>    * Pass all headers listed in the attributes parameter from the
> >>    [security] section to the hosts listed in the hosts parameter of the
> >>    same section (ticket #139)
> >> I am proposing myself as a release manager and the release to occur on
> >> next Friday (2019/06/07).
> >> My vote is obviously +1 for this release.
> >> Best regards,
> >> [1] http://www.zoo-project.org/trac/changeset/917
> >> [2] https://ci.appveyor.com/project/djay/trunk-t67ri/builds/24881108
> >> [3] https://ci.appveyor.com/project/djay/trunk-hp3tw/builds/24868734
> > Zoo-psc mailing list
> > Zoo-psc at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/zoo-psc
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20190601/a4100504/attachment.html>
More information about the Zoo-psc
