[ZOO-PSC] ZOO-Project 1.8.0 release candidate 1
    VENKATESH RAGHAVAN
    raghavan at osaka-cu.ac.jp
    Fri Dec 18 15:17:26 PST 2020
Hi Gerald and PSC,
Thanks for all you efforts with the new release candidate of
ZOO-Project!
Have great vacation and looking forward to a great year
ahead for the ZOO-Project community.
Venka
On 12/19/2020 7:49 AM, VENKATESH RAGHAVAN wrote:
> Hi Gerald and PSC,
> ZOO-Project!
> Venka
> On 12/19/2020 4:36 AM, Gérald Fenoy wrote:
>> Dear all,
>> As decided during the last PSC meeting, we are glad to present the new
>> released version of the ZOO-Project!
>> This new release contains new features and fixes.
>> Amongst new features, we can quote the docker-compose environment
>> created by Samuel Souk-Aloun which offer to deploy the ZOO-Project
>> with few very simple services. We may also refer to the new support of
>> the OGC API - Processes. Indeed, this version offers a preview of the
>> current, slightly modified, standard as discussed at OGC. Also, with
>> this new OGC API - Processes comes support a specific basic web user
>> interface that let the user browse and execute services.
>> Main new features and fixes :
>>    * Support raw response in OGC API - Processes
>>    * Add a ZOO-API section to the howtos documentation
>>    * OGC API - Processes support:
>>    https://github.com/gfenoy/wps-rest-binding/tree/change-request/95
>>    * Support two inputs/outputs syntaxes discussed (using json object
>>    or array of json object) for ZOO-Kernel and the HTML client
>>    * Fix issue in kvParseInput when memory!=load and handle session
>>    from the OGC API - Processes
>>    * Update OGC API - Processes documentation
>>    * Add open-api directory in utils services containing a reddis
>>    subscription example, the HTML UI and the display service using
>>    Cheetah templating system
>>    * Update the oas.cfg file to reflect new api definition
>>    * Include basic microdata in the HTML home page
>>    * Add HTML support for basic interractions with OGC API - Processes
>>    including execution of service from the service-desc link
>>    * OGC API - Processes added support for syncrhonous Execute requests
>>    * Reuse service_callback in OGC API - Processes when subscriber
>>    object is provided in the JSON request
>>    * OGC API - Processes implementation as available on 2020-10-19
>>    * Produce value string only when memory=load for Python support.
>>    * Make local files uris usable when cache is used
>>    * Make GDAL/profile service usable in case memory=protect
>>    * Add Dockerfile and docker-compose environment with pgbouncer, see
>> #177
>>    * Add documentation on how to use asyncrhonous execution using the
>> Javascript
>>    ZOO-API
>>    * Start simplification of the runRequest function
>>    * Integrate optional support for OGC API - Processing implementation
>>    * Add the optional handleText parameter to provide pure text for
>>    complex data node with mimetype="text/*"
>>    * Fix issue in case !JavaScript support is activated
>>    * Fix issue with GDAL profile service
>>    * Fix #172 for https support
>> I hope you will have great time using this new version and we will
>> wait for your feedbacks.
>> Best wishes,
>> Gerald Fenoy
>> Chair, ZOO-Project PSC
>> Zoo-psc mailing list
>> Zoo-psc at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/zoo-psc
More information about the Zoo-psc
