[ZOO-PSC] ZOO-Project 1.8.0 release candidate 1
    VENKATESH RAGHAVAN
    raghavan at osaka-cu.ac.jp
    Fri Dec 18 14:49:15 PST 2020
Hi Gerald and PSC,
Thanks for all you efforts with the new release candidate of
ZOO-Project!
Have great vacation and looking forward to a great year
ahead for the ZOO-Project community.
Venka
On 12/19/2020 4:36 AM, Gérald Fenoy wrote:
> Dear all,
> As decided during the last PSC meeting, we are glad to present the new released version of the ZOO-Project!
> This new release contains new features and fixes.
> Amongst new features, we can quote the docker-compose environment created by Samuel Souk-Aloun which offer to deploy the ZOO-Project with few very simple services. We may also refer to the new support of the OGC API - Processes. Indeed, this version offers a preview of the current, slightly modified, standard as discussed at OGC. Also, with this new OGC API - Processes comes support a specific basic web user interface that let the user browse and execute services.
> Main new features and fixes :
>    * Support raw response in OGC API - Processes
>    * Add a ZOO-API section to the howtos documentation
>    * OGC API - Processes support:
>    https://github.com/gfenoy/wps-rest-binding/tree/change-request/95
>    * Support two inputs/outputs syntaxes discussed (using json object
>    or array of json object) for ZOO-Kernel and the HTML client
>    * Fix issue in kvParseInput when memory!=load and handle session
>    from the OGC API - Processes
>    * Update OGC API - Processes documentation
>    * Add open-api directory in utils services containing a reddis
>    subscription example, the HTML UI and the display service using
>    Cheetah templating system
>    * Update the oas.cfg file to reflect new api definition
>    * Include basic microdata in the HTML home page
>    * Add HTML support for basic interractions with OGC API - Processes
>    including execution of service from the service-desc link
>    * OGC API - Processes added support for syncrhonous Execute requests
>    * Reuse service_callback in OGC API - Processes when subscriber
>    object is provided in the JSON request
>    * OGC API - Processes implementation as available on 2020-10-19
>    * Produce value string only when memory=load for Python support.
>    * Make local files uris usable when cache is used
>    * Make GDAL/profile service usable in case memory=protect
>    * Add Dockerfile and docker-compose environment with pgbouncer, see #177
>    * Add documentation on how to use asyncrhonous execution using the Javascript
>    ZOO-API
>    * Start simplification of the runRequest function
>    * Integrate optional support for OGC API - Processing implementation
>    * Add the optional handleText parameter to provide pure text for
>    complex data node with mimetype="text/*"
>    * Fix issue in case !JavaScript support is activated
>    * Fix issue with GDAL profile service
>    * Fix #172 for https support
> I hope you will have great time using this new version and we will wait for your feedbacks.
> Best wishes,
> Gerald Fenoy
> Chair, ZOO-Project PSC
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
More information about the Zoo-psc
