[ZOO-PSC] ZOO-Project 2.1.0 release proposal
Fabrice Brito fabrice.brito at terradue.com
Thu Jan 22 02:28:15 PST 2026
+1
Well done Gerald!
Fabrice Brito
@terradue
Roma, Italia
http://www.terradue.com
https://twitter.com/terradue
m +39 3406767340
On Thu, 22 Jan 2026, 09:47 nicolas bozon via ZOO-PSC, <
zoo-psc at lists.osgeo.org> wrote:
> +1 Nick
> Le jeu. 22 janv. 2026 à 09:45, Angelos Tzotsos via ZOO-PSC <
> zoo-psc at lists.osgeo.org> a écrit :
>> Great work!
>> +1
>> Angelos
>> On Thu, Jan 22, 2026 at 10:39 AM Gérald Fenoy via ZOO-PSC <
>>> Dear PSC members,
>>> I take advantage of the date to wish you all a wonderful New Year 2026!
>>> I come to you today to request your vote on the following motion:
>>> Releasing a new 2.1.0 version of the ZOO-Project with me as a release
>>> manager.
>>> Below is the list of significant changes since version 2.0.0:
>>>   * Add support for the /jobs/{jobId}/results/{outputId} endpoint
>>>   * Force update of the libsodium23 on ubuntu to fix CVE-2025-69277
>>>   * Fix urllib version 2.6.3 to fix CVE-2026-21441, CVE-2025-66418,
>>>   CVE-2025-66471, CVE-2025-50181, CVE-2025-50182
>>>   * Add profiles as per
>>> https://docs.ogc.org/DRAFTS/18-062r3.html#profile-uris
>>>   * Enhanced storage of metadata embedded within a CWL Application
>>> Pachage.
>>>   * Type detection for literal data output for proper result access.
>>>   * Use the cwl2ogc Python library for the transactional support and
>>>   schema definitions for inputs and output.
>>>   * C-API change signature of: printHeaders, printSessionHeaders,
>>>   printAFile, printProcessResponse, printDocument, printRawdataOutput,
>>>   printRawdataOutputs, outputResponse, runGetStatus, invokeCallback,
>>>   setReferenceUrl, printJResult, printJobStatus, printJobList,
>>>   printFilteredJobList, handleDRUError.
>>>   * Introduce the conversion from CWL type to LiteralData in
>>> documentation.
>>>   * ZOO-Project-DRU: Bind user to anonymous when no SERVICE_NAMESPACE is
>>>   defined.
>>>   * Add documentation on how to bind a format key to a schema using the
>>>   dedicated schemas section from the configuration file.
>>>   * Support CWL Custom Types with their corresponding format from OGC
>>> Process
>>>   Description.
>>>   * Support the format key in input/output schema from OGC Process
>>> Description.
>>>   * Add the CollectionDB.PrimitiveDataFormats table to the database
>>> containing
>>>   the possible formats key values and CWL Custom types.
>>>   * Change the strcuture of CollectionDB.ows_DataDescription to support a
>>>   format reference (data_format_id).
>>>   * Correct support for BoundingBox format in OGC Process Description.
>>>   * Store the zoofpm ip address in the status database to enable tracking
>>>   which zoofpm pod/container is used to run a process.
>>>   * Update GDAL based services to use the validateVRT for VRT used as
>>>   input file to ensure only the allowed paths are accessible.
>>>   * Add an isAllowedPath function to ensure the URL using file:// give
>>>   access only to the defined allowed paths, defined in the allowedPaths
>>> key
>>>   from the main section.
>>>   * Update the skaffold.yaml file for easy deployment of the ZOO-Project
>>>   with DRU and CWL support on a local cluster in different flavors
>>>   * Update the ZOO_DEBUG to use color for messages (if stderr is a tty)
>>>   * Update variables naming, including the main configuration file name
>>>   * Update ZOO_DEBUG function to use LOG_MESSAGE_FORMAT to format the
>>>   debug messages, using the iZooLogLevel integer to decide between:
>>> DEBUG,
>>>   INFO, WARN, ERROR, FATAL. Comes with it associated --with-log-format
>>> option.
>>>   * Store temporary files associated with a run made by an authenticated
>>>   user in a non browsable directory, add a browse service to access these
>>>   files.
>>>   * Remove Miniconda3 from the ZOO-Project-DRU docker image to avoid
>>>   conflict with shared libraries.
>>>   * Add getServicesNamespacePath, printAFile, handlePackage functions to
>>>   the C-API.
>>>   * Add support for "File" inputs in CWL to be identified as ComplexData
>>>   as defined in the Table 3 of the OGC Best Practice for Earth
>>> Observation
>>>   Application Package.
>>>   * Add initial support for /processes/{processId}/package as defined in
>>> the
>>>   OGC API - Processes - Part2: Deploy, Replace, Undeploy draft.
>>>   * Ensure the mutable processes cannot be executed syncrhonously.
>>>   * Ensure that the invokeBasicCallback function is used in case the
>>>   service execution failed.
>>>   * Fix issue when multiple filters are used to filter the jobs list.
>>>   * Add support for x-logo in the info object of the OpenAPI.
>>>   * Add keywords in the process description if any are defined in the
>>>   service metadata.
>>>   * Preserve datatype for literal values that should be passed to the
>>>   cwl runner.
>>>   * Expose complex metada information such as author and contributor
>>>   within the process descrition for OGC API - Processes.
>>>   * Support recording metadata and author for processes deployed from
>>> CWL.
>>>   * Add gdalmdiminfo and gdalmdimtranslate services
>>>   * Update support for OGC API - Processes - Part 3: Workflows
>>> I include my +1 to the upcimng release;
>>> Best regards,
>>> Gerald Fenoy
>>> gerald.fenoy at geolabs.fr
>>> Chair, ZOO-Project PSC
>>> ZOO-PSC mailing list
>>> ZOO-PSC at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/zoo-psc
>> Angelos Tzotsos, PhD
>> President, Board of Directors
>> Open Source Geospatial Foundation
>> https://www.osgeo.org/member/angelos-tzotsos/
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20260122/4e2bfad0/attachment.htm>
More information about the ZOO-PSC mailing list
