[ZOO-PSC] ZOO-Project 2.1.0 release proposal
Venkatesh Raghavan raghavan at omu.ac.jp
Thu Jan 22 02:11:32 PST 2026
Very Happy New Year to all of you!
+1 for the motion for ZOO-Project 2.1.0 release.
Venka
On 1/22/2026 5:29 PM, Gérald Fenoy via ZOO-PSC wrote:
> Dear PSC members,
> I take advantage of the date to wish you all a wonderful New Year 2026!
> I come to you today to request your vote on the following motion:
> Releasing a new 2.1.0 version of the ZOO-Project with me as a release manager.
> Below is the list of significant changes since version 2.0.0:
>    * Add support for the /jobs/{jobId}/results/{outputId} endpoint
>    * Force update of the libsodium23 on ubuntu to fix CVE-2025-69277
>    * Fix urllib version 2.6.3 to fix CVE-2026-21441, CVE-2025-66418,
>    CVE-2025-66471, CVE-2025-50181, CVE-2025-50182
>    * Add profiles as per https://docs.ogc.org/DRAFTS/18-062r3.html#profile-uris
>    * Enhanced storage of metadata embedded within a CWL Application Pachage.
>    * Type detection for literal data output for proper result access.
>    * Use the cwl2ogc Python library for the transactional support and
>    schema definitions for inputs and output.
>    * C-API change signature of: printHeaders, printSessionHeaders,
>    printAFile, printProcessResponse, printDocument, printRawdataOutput,
>    printRawdataOutputs, outputResponse, runGetStatus, invokeCallback,
>    setReferenceUrl, printJResult, printJobStatus, printJobList,
>    printFilteredJobList, handleDRUError.
>    * Introduce the conversion from CWL type to LiteralData in documentation.
>    * ZOO-Project-DRU: Bind user to anonymous when no SERVICE_NAMESPACE is
>    defined.
>    * Add documentation on how to bind a format key to a schema using the
>    dedicated schemas section from the configuration file.
>    * Support CWL Custom Types with their corresponding format from OGC Process
>    Description.
>    * Support the format key in input/output schema from OGC Process Description.
>    * Add the CollectionDB.PrimitiveDataFormats table to the database containing
>    the possible formats key values and CWL Custom types.
>    * Change the strcuture of CollectionDB.ows_DataDescription to support a
>    format reference (data_format_id).
>    * Correct support for BoundingBox format in OGC Process Description.
>    * Store the zoofpm ip address in the status database to enable tracking
>    which zoofpm pod/container is used to run a process.
>    * Update GDAL based services to use the validateVRT for VRT used as
>    input file to ensure only the allowed paths are accessible.
>    * Add an isAllowedPath function to ensure the URL using file:// give
>    access only to the defined allowed paths, defined in the allowedPaths key
>    from the main section.
>    * Update the skaffold.yaml file for easy deployment of the ZOO-Project
>    with DRU and CWL support on a local cluster in different flavors
>    * Update the ZOO_DEBUG to use color for messages (if stderr is a tty)
>    * Update variables naming, including the main configuration file name
>    * Update ZOO_DEBUG function to use LOG_MESSAGE_FORMAT to format the
>    debug messages, using the iZooLogLevel integer to decide between: DEBUG,
>    INFO, WARN, ERROR, FATAL. Comes with it associated --with-log-format option.
>    * Store temporary files associated with a run made by an authenticated
>    user in a non browsable directory, add a browse service to access these
>    files.
>    * Remove Miniconda3 from the ZOO-Project-DRU docker image to avoid
>    conflict with shared libraries.
>    * Add getServicesNamespacePath, printAFile, handlePackage functions to
>    the C-API.
>    * Add support for "File" inputs in CWL to be identified as ComplexData
>    as defined in the Table 3 of the OGC Best Practice for Earth Observation
>    Application Package.
>    * Add initial support for /processes/{processId}/package as defined in the
>    OGC API - Processes - Part2: Deploy, Replace, Undeploy draft.
>    * Ensure the mutable processes cannot be executed syncrhonously.
>    * Ensure that the invokeBasicCallback function is used in case the
>    service execution failed.
>    * Fix issue when multiple filters are used to filter the jobs list.
>    * Add support for x-logo in the info object of the OpenAPI.
>    * Add keywords in the process description if any are defined in the
>    service metadata.
>    * Preserve datatype for literal values that should be passed to the
>    cwl runner.
>    * Expose complex metada information such as author and contributor
>    within the process descrition for OGC API - Processes.
>    * Support recording metadata and author for processes deployed from CWL.
>    * Add gdalmdiminfo and gdalmdimtranslate services
>    * Update support for OGC API - Processes - Part 3: Workflows
> I include my +1 to the upcimng release;
> Best regards,
> Gerald Fenoy
> gerald.fenoy at geolabs.fr
> Chair, ZOO-Project PSC
> ZOO-PSC mailing list
> ZOO-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
More information about the ZOO-PSC mailing list
