[Workshops] Machine setup
Etienne Dube etdube at gmail.com
Mon Sep 28 18:43:19 EDT 2009
Hi Justin,
Good, it's fine for us too. I'll put JDK 6u16 in the software to be
installed. JAVA_HOME can point to it and our Tomcat instance will be happy.
Etienne
Justin Deoliveira a écrit :
> Hi Etienne,
> We require a JDK (not just a JRE) for GeoServer to run. Version 6 will
> be fine for us.
> -Justin
> Etienne Dube wrote:
>> Hi,
>> Is there any other workshop that requires a Java JRE? We'll be using
>> the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with FOSS).
>> Everything else is self-contained in a directory under C:\. Could
>> Java be pre-installed on the machines? Any possible version conflicts
>> (i.e. if anyone requires a Java 5 JRE)?
>> Thanks,
>> Etienne
>> Mark Leslie a écrit :
>>> Damnit, this one slipped past me last week.
>>> All we've got going so far is
>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>> which really isn't up to this task, and is already incomplete.  As a
>>> general rule, I would prefer to have nothing installed as an
>>> automatic service.  We can setup links to load applications/services
>>> as needed, but it seems easiest to not have everything running by
>>> default.  That way port conflicts shouldn't be a hugh issue
>>> (optimism?).
>>> It will still cause collisions on install directories, in particular
>>> for workshops that involve an installation step, and service names.
>>> Mark
>>> Justin Deoliveira wrote:
>>>> Hi folks,
>>>> Apologies if this has been covered already but is there a wiki page
>>>> up that lists all the software that is going to be installed on all
>>>> the workshop machines? I know last year we set this up and it was
>>>> quite useful in order to resolve any version conflicts, and more
>>>> importantly any port conflicts between running services.
>>>> -Justin
>>> Conference-workshops mailing list
>>> Conference-workshops at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
More information about the Conference-workshops mailing list
