[Workshops] Machine setup
Etienne Dube etdube at gmail.com
Mon Sep 28 19:05:57 EDT 2009
Yep it'll be running on 8080, but the tomcat instance will be manually
started during the workshop (it won't be installed as a service, only
launched from a batch file). Like Mark said in this thread, I think it's
a good idea to have nothing installed as an automatic service, to avoid
any port conflict.
Justin Deoliveira a écrit :
> Cool. Just to ensure there are no conflicts i will set up GeoServer to
> run on a different port than 8080. Assuming that Tomcat will be indeed
> running on 8080?
> Etienne Dube wrote:
>> Hi Justin,
>> Good, it's fine for us too. I'll put JDK 6u16 in the software to be
>> installed. JAVA_HOME can point to it and our Tomcat instance will be
>> happy.
>> Etienne
>>> Hi Etienne,
>>> We require a JDK (not just a JRE) for GeoServer to run. Version 6
>>> will be fine for us.
>>> -Justin
>>> Etienne Dube wrote:
>>>> Hi,
>>>> Is there any other workshop that requires a Java JRE? We'll be
>>>> using the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with
>>>> FOSS). Everything else is self-contained in a directory under C:\.
>>>> Could Java be pre-installed on the machines? Any possible version
>>>> conflicts (i.e. if anyone requires a Java 5 JRE)?
>>>> Thanks,
>>>> Etienne
>>>> Mark Leslie a écrit :
>>>>> Damnit, this one slipped past me last week.
>>>>> All we've got going so far is
>>>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>>>> which really isn't up to this task, and is already incomplete.  As
>>>>> a general rule, I would prefer to have nothing installed as an
>>>>> automatic service.  We can setup links to load
>>>>> applications/services as needed, but it seems easiest to not have
>>>>> everything running by default.  That way port conflicts shouldn't
>>>>> be a hugh issue (optimism?).
>>>>> It will still cause collisions on install directories, in
>>>>> particular for workshops that involve an installation step, and
>>>>> service names.
>>>>> Mark
>>>>> Justin Deoliveira wrote:
>>>>>> Hi folks,
>>>>>> Apologies if this has been covered already but is there a wiki
>>>>>> page up that lists all the software that is going to be installed
>>>>>> on all the workshop machines? I know last year we set this up and
>>>>>> it was quite useful in order to resolve any version conflicts,
>>>>>> and more importantly any port conflicts between running services.
>>>>>> -Justin
>>>>> _______________________________________________
>>>>> Conference-workshops mailing list
>>>>> Conference-workshops at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
More information about the Conference-workshops mailing list
