[Workshops] Machine setup
Tim Schaub tschaub at opengeo.org
Mon Sep 28 21:05:38 EDT 2009
Sorry if this is asking the obvious, but does Apache get 80 (and will it
be running)?
I understand the desire to limit what workshops install and run as
services, but I think it also makes sense to limit the number of things
that every participant has to click through.
I was planning on writing up instructions for configuring Apache to
proxy GeoServer on port 80 and set up an alias for the root of the
workshop folder.
All the OpenLayers material assumes this (http://localhost/geoserver and
http://localhost/ol_workshop).
I had been planning on walking participants through starting GeoServer.
  And I had been assuming we'd have an http server running on 80 that
could get to the workshop folder.
Tim
Etienne Dube wrote:
> Yep it'll be running on 8080, but the tomcat instance will be manually
> started during the workshop (it won't be installed as a service, only
> launched from a batch file). Like Mark said in this thread, I think it's
> a good idea to have nothing installed as an automatic service, to avoid
> any port conflict.
> Justin Deoliveira a écrit :
>> Cool. Just to ensure there are no conflicts i will set up GeoServer to
>> run on a different port than 8080. Assuming that Tomcat will be indeed
>> running on 8080?
>> Etienne Dube wrote:
>>> Hi Justin,
>>> Good, it's fine for us too. I'll put JDK 6u16 in the software to be
>>> installed. JAVA_HOME can point to it and our Tomcat instance will be
>>> happy.
>>> Etienne
>>>> Hi Etienne,
>>>> We require a JDK (not just a JRE) for GeoServer to run. Version 6
>>>> will be fine for us.
>>>> -Justin
>>>> Etienne Dube wrote:
>>>>> Hi,
>>>>> Is there any other workshop that requires a Java JRE? We'll be
>>>>> using the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with
>>>>> FOSS). Everything else is self-contained in a directory under C:\.
>>>>> Could Java be pre-installed on the machines? Any possible version
>>>>> conflicts (i.e. if anyone requires a Java 5 JRE)?
>>>>> Thanks,
>>>>> Etienne
>>>>> Mark Leslie a écrit :
>>>>>> Damnit, this one slipped past me last week.
>>>>>> All we've got going so far is
>>>>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>>>>> which really isn't up to this task, and is already incomplete.  As
>>>>>> a general rule, I would prefer to have nothing installed as an
>>>>>> automatic service.  We can setup links to load
>>>>>> applications/services as needed, but it seems easiest to not have
>>>>>> everything running by default.  That way port conflicts shouldn't
>>>>>> be a hugh issue (optimism?).
>>>>>> It will still cause collisions on install directories, in
>>>>>> particular for workshops that involve an installation step, and
>>>>>> service names.
>>>>>> Mark
>>>>>> Justin Deoliveira wrote:
>>>>>>> Hi folks,
>>>>>>> Apologies if this has been covered already but is there a wiki
>>>>>>> page up that lists all the software that is going to be installed
>>>>>>> on all the workshop machines? I know last year we set this up and
>>>>>>> it was quite useful in order to resolve any version conflicts,
>>>>>>> and more importantly any port conflicts between running services.
>>>>>>> -Justin
>>>>>> _______________________________________________
>>>>>> Conference-workshops mailing list
>>>>>> Conference-workshops at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Conference-workshops mailing list
