[OSGeo-Discuss] Re: [Gvsig_english] New site demonstrating the use of Free & Open Source Software
Simon Cropper scropper at botanicusaustralia.com.au
Wed Apr 27 19:02:16 PDT 2011
On 28/04/11 11:28, Jody Garnett wrote:
> You should find that the committees mentioned are aware of these issues. In
> particular the osgeo live project is standardising on the use of the natural
> earth dataset in order to be above board.
This is good but very few people actually do work at that scale. I hope
that now we have some data at a finer resolution we will see some other
tutorials demonstrating techniques typically done on a day to day basis.
> If it helps; for the next release of uDig I was going to switch to the
> natural earth dataset in order to better fit with OSGeo live; and be
 > more generally interesting for a world wide audience.
This sounds good but as stated most users work at a regional level not
continent wide level.
> From my standpoint it is annoying having any number of projects asking for
> content to be written; and no procedures in place to easily accept the
> content that is available.
> The first project that sits down and defines how submit word, pdf, html,
> rst, odf etc... (with manual steps if needed) will have a much greater
> chance of success. Perhaps that project will be yours?
I agree. I have resisted finalising my tutorial on 'preparing tutorials'
so I can iron out any nuances before asking others to follow the same
procedure. I think that after a couple of more tutorials I should be
happy with the process and will publish my notes.
I have also developed a few simple python routines that make those
finicky things deeded to make a webpage functional, easy to do. These
will be published and explained on the scripting subdomain.
So far I have...
1. A reasonable HTML template (no need for contributor to change)
2. A reasonable style setup (no need for contributor to change)
3. Sound metadata model
4. Appropriate and diverse dataset to demonstrate techniques
5. Easy screen capturing procedure
6. A range of simple to use scripts to automate those few irritating
tasks (gather images data and insert tags into HTML document,
create/maintain navigation lists, synchronise metadata throughout
website, create PDFs).
Most of these are reasonably stable now, so as stated above, after a few
more published tutorials I will be releasing these for others to use.
Cheers Simon
    Simon Cropper
    Principal Consultant
    Botanicus Australia Pty Ltd
    PO Box 160, Sunshine, VIC
    W: www.botanicusaustralia.com.au
More information about the Discuss mailing list
