[fdo-internals] Making the cmake build usable with MapGuide
Greg Boone greg.boone at autodesk.com
Mon Jun 17 08:23:26 PDT 2013
Sounds good.
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, June 17, 2013 10:43 AM
To: fdo-internals at lists.osgeo.org
Subject: Re: [fdo-internals] Making the cmake build usable with MapGuide
Yep, that works.
Renaming the BinaryReader class to SdfBinaryReader in the SDF provider (and renaming the BinaryWriter class to SdfBinaryWriter for good measure) resolves this problem and produces a cmake build that can be linked with MapGuide.
I think this solution beats trying to figure out the magical combination of compiler/linker flags that has been wonderfully obscured by the combination of automake and libtool.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Making-the-cmake-build-usable-with-MapGuide-tp5060074p5060618.html
Sent from the FDO Internals mailing list archive at Nabble.com.
fdo-internals mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
