[FOSS-GPS] rtkrcv static
anthony wooldridge arwooldridge at googlemail.com
Wed Jun 15 01:19:37 PDT 2016
I too liked the ease of use the GUI RTKNAVI and associated apps.
Its not the answer you were looking for but I notice that Embarcardo are
doing a deal on the Starter edition of C++ builder for £48 ( windows
only?) , only valid for a few days till 20th June, also there's a trial
version of the full suite you can download and use for a month. Maybe
there will be other offers following. The full professional version is
still priced out of reach for non commercial use, but there might be a
student version available on special application. I am not associated
with Embarcardo or endorse there products in any way.
I have not used the non GUI console apps much  but you need to set all
the parameters up correctly of course, the manual should help here.
Regards
Anthony
On 14/06/2016 20:31, Dan Cook wrote:
> I am just about complete with my small project of implementing the CMR
> protocol for RTKLIB including CMR+, high speed observables (5Hz, 10Hz,
> 20Hz) and “Leica” GLONASS observables.
> In order to facilitate testing I have set up a baseline in my backyard
> consisting of two survey grade L1/L2 receivers on two fixed height
> tripods spaced five meters apart. I treat one as a base and the other
> as a rover. Standalone this works very well, both with RTCM3 and with
> CMR/CMR+/CMR 5Hz output from the base.
> Before testing my CMR code, I need to get a "baseline comparable test"
> using RTCM3 to work. This is no problem if I use the RTKNAVI binary.
> Instant fixed solution. Wow that RTKNAVI really works well. But I
> can't build a new RTKNAVI with CMR support, I don't have the required
> build environment for it, so won't be able to use it for CMR
> testing/debugging. I can build RTKRCV. I can build it both on Windows
> with Visual Studio 2012 Express and on a Fedora Linux with gcc.
> Unfortunately, unlike RTKNAVI, I haven't been able to get RTKRCV to
> work. I've barely got it doing SINGLE solutions. STATIC always fails
> with "no double-differenced residual" errors and outputs only SINGLE
> solutions.
> Hmm, what could I be doing wrong? I've tried playing around with the
> settings in RTKRCV.CONF to no avail. I can't say I know the internals
> of RTKLIB well enough to get past this without help. And if I can't
> get past this, I won't be able to complete my project.
> Anyone have any ideas?
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160615/eae88359/attachment.html>
More information about the FOSS-GPS mailing list
