[FOSS4G-UK] Call for Talks
Nick Bearman nick at geospatialtrainingsolutions.co.uk
Thu Jun 8 01:39:21 PDT 2023
Hi Dan,
Thanks - this is fine. Remind me again when we get to 31st July, and we
can always add 'No workshops in Bristol' if needed.
Best wishes,
Nick.
On 07/06/2023 17:47, Dan Ormsby wrote:
> Hi Nick,
> On the call for talks, one issue for Bristol is that we will have to
> hire an additional room for workshops, which we can do and cancel free
> of charge provided our cancellation is at least 1 month in advance.
> We therefore need to know definitively before 7 August as to whether
> or not we are going to have any workshops in Bristol to avoid
> additional charges. That would be fine if the call has a 31st July
> deadline, but not if it is extended to 7 August.  I guess 31 July
> could always be firm deadline for workshops in Bristol even if other
> format talks could have an extended deadline to 7 August. Other than
> that, call for talks all looks good to me :-).
> Dan
> On Wed, 7 Jun 2023 at 14:53, Nick Bearman
> <nick at geospatialtrainingsolutions.co.uk> wrote:
>     Hello,
>     I have checked through the Call for Talks, and it is shared on Google
>     Drive at
>     https://docs.google.com/forms/d/1vbnd_1SWFyGFWP4ut-ezNQaRCZrLV9QX6QrrxY8Zp1Q/edit.
>     We need to choose an initial deadline. We discussed an initial
>     deadline
>     of 31st July, with possible extension to 7th Aug. Is everyone ok
>     with this?
>     I have also added the notes about a) workshop availability and b)
>     providing PDF slides 24 hours beforehand.
>     Any other comments / suggestions?
>     I will aim to add some details to the website soon
>     (today/tomorrow) and
>     we can release this together.
>     Best wishes,
>     Nick.
>     Nick Bearman
>     +44 (0) 7717745715
>     Due to my own life/work balance, you may get emails from me
>     outside of normal working hours. Please do not feel any pressure
>     to respond outside of your own working pattern.
>     FOSS4G-UK mailing list
>     FOSS4G-UK at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/foss4g-uk
> I’m Dan Ormsby, UK Lead at *Sparkgeo*.
> We provide geospatial expertise to tech companies.
> Reach me at dormsby at sparkgeo.com or on LinkedIn
> <https://www.linkedin.com/in/danielormsby/>
> +44 7880794939
Nick Bearman
+44 (0) 7717745715
Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230608/501c21ca/attachment-0001.htm>
More information about the FOSS4G-UK mailing list
