[fusion-users] Speed of Fusion vs MapFish (OpenLayers)
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Oct 29 17:58:34 EDT 2008
A complete guess:
Fusion uses the default ratio 1.5, meaning that the
image downloaded/rendered is twice the size.
If you set the ratio to 1.0 in should cut time in half (almost).
I don't know where to set this with Fusion.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew Parker skrev:
> I am not sure if there is a way to make Fusion render maps as fast as
> OpenLayers. At this time, I just need a yes or no answer.
> For example, it would be great if I could make my current Fusion
> application (http://216.93.173.156/testing/) draw the map as fast as
> my current OpenLayers application (http//:webgis.source3.com) and my
> MapFish test at (http://http://216.93.173.156/MFtest/).
> What I am using for a comparison is the Topo Map Layer with the USGS
> wells (the data is limited to New Mexico, USA) at a scale of about
> 1:100,000. When I zoom and pan, I like how fast OpenLayers/MapFish
> redraws.
> I went ahead and turned on the two layers that I am using for a
> comparison in MapFish test and my Fusion test.
> The topo is from TerraServer. The USGS data is in PostGIS.
> thanks,
> ~andrew
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
