[fusion-users] Maptips on Mapserver (was: PanQuery and pink backgrounds)
Paul Spencer pspencer at dmsolutions.ca
Tue Sep 16 14:37:26 EDT 2008
Nice work, Marc!  Here's what I'd like to do with this widget:
1) write a php script for MapGuide equivalent to the MapServer one you
have written - both will take the same parameters
2) return the same JSON object from both scripts
3) make the client side completely generic to both architectures
I've created a ticket for this: http://trac.osgeo.org/fusion/ticket/127
If you are willing, can you attach your PHP script, Maptip2.js and
anything else we might need to incorporate this into trunk?
Cheers
Paul
On 16-Sep-08, at 2:16 PM, Marc Pfister wrote:
> Paul Deschamps wrote
>> One thing you can try is to just offset it a little from the cursor
>> position. it's not
>> a fix but if we are able to get the selection issue resolved  it
>> would be less obvious.
>> Your widget is a good basis thus far. Here's one method you can do
>> to preform the query:
>> call a separate php script in the widget and in that script open up
>> the mapfile then do
>> a queryByRect and return the results in json.
> Here's Maptips fixed to use a separate PHP script for MapServer. It
> now seems to work pretty nicely. The code should work for both
> MapGuide and Mapserver, though I don't have a MapGuide install any
> more to test against.
> I've also added extension parameters for MapServer to specify which
> fields in the feature class to use for the text and hyperlink in the
> MapTip.
> And to help it work with PanQuery, I added a 5 pixel offset to the
> Maptip div so that it isn't under the mouse and taking away focus. I
> considered making it an extension parameter too but maybe that's not
> needed.
> http://209.20.81.81/fusion/templates/mapserver/corning/
> http://209.20.81.81/fusion/widgets/Maptip2.js
> Marc
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
