[fusion-users] MapGuide HTTP tiles with Fusion?
Zac Spitzer zac.spitzer at gmail.com
Mon Mar 2 03:19:27 EST 2009
fusion 2 is going to support arbitrary openlayers layers i believe :)
the pain is still the manual configuration required to set things up
z
On Mon, Mar 2, 2009 at 7:09 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Hi all,
> Zac's done some work getting MapGuide tiles to serve up as straight HTTP requests.  This technique, combined with multiple hosts (maptiles1.nanaimo.ca, maptiles2.nanaimo.ca, etc) would really make MapGuide tile serving smoke.
> http://trac.openlayers.org/ticket/1622
> Does anyone know if this method could be:
>  - supported as a layer type under Fusion 2
>  - added to a Fusion map as a "base layer" at the bottom of a dynamic MapGuide layer?
> And, failing this, can a standard MapGuide tiled map be used as a base layer at the bottom of a dynamic MapGuide layer in a single Fusion map?
> This would be a "killer feature" for me.  If it can't currently be done, what kind of effort would be involved in supporting this?
> Thanks,
> Jason
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-users mailing list
